2.4 PA in ebay
OH6MQM
2.4 PA in ebay
Post by OH6MQM » Sun Feb 12, 2023 3:02 pm
https://www.ebay.com/itm/20408…a99502:g ... Sw4JBjbO6B
2,3GHz DOUBLE QRO RF linear amplifier, 2x BLC9G22XS-400AVT with cover.
Is there modification instruction available for this or another one present at e-bay ?
Br. Esko Petäjä
OH6MQM
M5TXJ
Re: 2.4 PA in ebay
Post by M5TXJ » Sun Feb 12, 2023 8:29 pm
That PA reportedly doesn't modify well, however this one does.
https://www.ebay.co.uk/itm/204036129772
73 Dave
OH6MQM
Re: 2.4 PA in ebay
Post by OH6MQM » Mon Feb 13, 2023 7:00 am
Hello Dave
Do you have instruction for modification ?
Br. Eskop
M5TXJ
Re: 2.4 PA in ebay
Post by M5TXJ » Mon Feb 13, 2023 7:42 am
g6hfs
Re: 2.4 PA in ebay
Post by g6hfs » Mon Feb 13, 2023 9:35 am
Hi, this pallet modifies well mine gives a good 100watts on both sides.
Re: 2.4 PA in ebay
Post by g0mjw » Mon Feb 13, 2023 10:04 am
That's only 10W?
g6hfs
Re: 2.4 PA in ebay
Post by g6hfs » Mon Feb 13, 2023 10:30 am
Hi Mike,
it has a switched multiplayer, look top right corner x1, x10 and x100 it’s switch to x10
Re: 2.4 PA in ebay
Post by g0mjw » Mon Feb 13, 2023 12:32 pm
Interesting. I thought those meters only did low power as written on the switches on the front. I could have bought one for 23cm last year but passed as it only went to 20W.
Is there another switch on the back? If so they could be useful given the difficulty in getting power meters at 2.4 GHz/
g6hfs
Re: 2.4 PA in ebay
Post by g6hfs » Mon Feb 13, 2023 1:07 pm
Hi Mike,
This is the S version, back when I bought it they offered to do the mods to the V (200w) model they added the switch and fitted components required to the pcb, and calibrated it but that was a good few years ago, also have 200w dummy load for 2.5GHZ. (still gets quite warm at 100w)
OH6MQM
Re: 2.4 PA in ebay
Post by OH6MQM » Tue Feb 14, 2023 6:02 am
Hello
Thanks from info, I bought one unit Yesterday
One practical question about removing component.
Instruction says that using hotplate, i do not have hotplate
Just thinking if they can be removed just mechanically and rest with heatgun ?
i have also re-soldering unit with vacum pump ?
Br. Esko P
