MiniTiounerPro V2 CONFIG HELP
G8KOE
Post by G8KOE » Fri Jan 06, 2023 12:17 pm
Hardware MiniTiounerPro V2.
Software Minitune v1.01.0r
I would like to set the default audio level at switch on.
Been looking at the config file but can't find and reference to the audio.
Can anyone help please.
73's
Martin
G8KOE
G8HKN
Re: MiniTiounerPro V2 CONFIG HELP
Post by G8HKN » Sat Jan 07, 2023 1:47 pm
Hi Martin,
Nothing in config file but
If you right click on loudspeaker in task bar and select volume mixer
you can adjust it there.
73 Roger G8HKN.
Screenshot (18).png (63.39 KiB) Viewed 9021 times
G8KOE
Post by G8KOE » Sat Jan 07, 2023 5:59 pm
Hi Roger,
If you adjust the volume with mixer has the same effect as the slider on Minitiouner software.
Next time you restart the software back to 50%
I will keep looking.
Thanks for the reply.
73's
Martin
G8KOE
G8HKN
Post by G8HKN » Sat Jan 07, 2023 9:19 pm
ok martin I wasn't sure.
I don't have problem as I use active speakers
with a big volume knob which stays were I leave it.
73 Roger G8HKN
