20 GHz Spectrum Analyser Break Up Parts up for Grabs
I have a number of the 18GHz SMA Relays 28 volt non latching £30 posted in the UK
The other items pictured I am open to offers
1.75-4.3 GHz YIG Oscillator and YIG Filter
Balanced Mixers x2
2060 MHz Oscillator +13dBm
2,4GHz Directional Coupler -6db x 2
227 MHZ bandpass filter
2GHz Low Pass Filter
Anzac Balanced Mixer
Avantek 2.3 GHz amplifier
Numerous lenghs of 4mm semi rigid copper clad cable ..all terminated in SMA
[Moderator - Edited to fix duplicate pix.]
Balanced Mixers x2
- P1120131.JPG (148 KiB) Viewed 7304 times
Re: 20 GHz Spectrum Analyser Break Up Parts up for Grabs
I will try again with attachments which seem to have a mind of their own!
- P1120134.JPG (150.5 KiB) Viewed 7302 times
Hi there,
Interested in the semi rigid cables.
73 Dave.
73 Dave.
Let me know what sort of lengths you are looking for
See attached ..Also some SMA 18GHz attenuators 3 6 and 10dB
Hi again Adrian,
A couple of the longer ones are all I need, preferably one with a right angle plug if there is one, if no one has grabbed all the attenuators I'd like a 10dB one if possible.
Many thanks.
73 Dave
Many thanks.
73 Dave
How long is long!
Attenuators have gone I am afraid
Andy JNT has identified a couple of Step Recovery Diodes amongst the cache...open to offers
There is also a 100MHz crystal marker
See attched
See attched
6-8" or thereabouts if possible Adrian.
73 Dave.
73 Dave.
