FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.80
G8KWR
Re: FreeStreamCoder Software to Generate Mpeg-TS Streams >> soon V2.72
Post by G8KWR » Wed Oct 27, 2021 5:36 pm
Thanks for the info. I have been looking through the Intel documentation, and I think that the issue is just that they do not support hardware encoding of H.262. Probably "just" need a newer, faster computer to do the software encoding. When I eventually manage to get onto QO100, then the hardware encoding may be relevant.
Thanks to everyone for the help.
Roger
Jabi
Post by Jabi » Fri Oct 29, 2021 10:35 am
Is possible, please, send me one *.bat for work FreeStreamCoder with OBS and Pluto?
73,s de Jabi, ea2aru.
Jabi
Post by Jabi » Fri Oct 29, 2021 10:37 am
FreeStreamConfiguration:
My Pluto is in:192.168.1.8
What port is the correct for work udp with it? 8282?
Please send me news ...
Post by g0mjw » Fri Oct 29, 2021 12:07 pm
Jabi - yes but this information is in the manual which should be the first call rather than asking each detail in the forum.
See http://192.168.1.8/doc.php
The manual states "PlutoSDR wait for transport stream over udp on port 8282."
There is also the Wiki, also linked from the documentation page https://wiki.batc.org.uk/Custom_DATV_Fi ... _the_Pluto
F5UUI's excellent tutorials https://www.f5uii.net/en/transmit-datv- ... o=plutodvb
Several articles in CQTV
Google.
Jabi
Post by Jabi » Sun Oct 31, 2021 5:47 am
Dear Mike:
Not problem. Your software is running 100% ok. The port is 8282.
Many tns for all.
G7JTT
Post by G7JTT » Tue Nov 02, 2021 9:06 pm
GE all,
Firstly thanks too Dominique for all the work you've put into FreeStreamCoder it has made live so much easier when using IPTSin with the Portsdown.
The one issue I've been having is lip-sync my work around has been to put a sync offset of around -950ms in the advanced audio properties in OBS, well after doing some testing this evening I think I've found the cause. Click on the Tools tab then go to the VirtualCam tab, Stop the VirtualCam then play with the Buffered Frames Slider to find the sweet spot to sync the audio and video, in my case it was 25.
Hope this helps others 73 John
P.s don't forget to reset any off sets you previously used in the advanced audio properties back to 0ms
F1EJP
Re: FreeStreamCoder Software to Generate Mpeg-TS Streams >> New V2.75
Post by F1EJP » Tue Nov 02, 2021 9:07 pm
Hello
Here is the new version 2.75
>> Includes one of the latest version of ffmpeg 4.4
Small corrections following discussions and tests with Robert VK3IE> Thanks to him for his participation!
- implementation of checks on the values ​​of the PID and SID tables which crashed ffmpeg
- tests seem ok on Windows 11
http://www.vivadatv.org//viewtopic.php?f=78&t=866
73 Dominique F1EJP
g4saq
Post by g4saq » Thu Nov 04, 2021 2:29 pm
I have a simple batch file to start all my DATV programs automatically (OBS - FreeStream coder - pluto.php).
My batch file has the line "start C:\F1EJP\F1EJP-FreeStreamCoder-v02.73.exe" at the moment.
Is it possible to make Freestream coder start encoding automatically, either from the batch file or from its ini file, please?
F1EJP
Post by F1EJP » Thu Nov 04, 2021 7:29 pm
Hello G4SAQ
Good idea i made a new version for this V2.76
to make Freestream coder start encoding automatically:
In the file C:\F1EJP\mem.ini modifie new parameter START=0 by START=1
73 Dominique F1EJP
