R2 and R3 on GPIO board
G0SFJ
Post by G0SFJ » Tue Aug 10, 2021 10:37 am
Just collecting the parts for the GPIO breakout board.
I will use an IR sensor from a new TiVo which i believe (therefore) to be 3.3 volts. I will check out the identifying earth pin as it is still on the original board.
Silly question : So on the GPIO board, should I leave R2 blank and put in a 4K7 to R3 ? Or should I short across R2 as well? Or anything else?
I am slightly flummoxed at this one, sorry!
I'm sure it is obvious to most people, but help will be appreciated.
many thanks
73 de andy g0sfj
DL1BJV
Re: R2 and R3 on GPIO board
Post by DL1BJV » Tue Aug 10, 2021 12:49 pm
Hello Andy,
I have omitted R2 and soldered a 100 Ohm resistor in for R3. This has been working fine for me. A 4K7 resistor for R3 would also work.
I am using a 3V3 IR receiver. It is important to check the pinout as they do vary. The IR receiver which I am using is a 38KHz type.
Some more useful information can be found on the BATC Wiki, here is a link if you have not found this before:
https://wiki.batc.org.uk/Ryde_GPIO_breakout.
Hope this has helped,
7e Wolfgang
G0SFJ
Post by G0SFJ » Tue Aug 10, 2021 12:54 pm
Thanks Wolfgang. I will omit R2 then. I have a 4K7.
You are quite right about the pinouts on the IR receivers. i have just found out that both the receivers on my surplus boards have the centre pin to ground (these are British STB's, Virgin TiVo and Sky HD) so I have bought the proper one off <popular auction site>.
thanks again es 73 de g0sfj
G0SFJ
Post by G0SFJ » Sun Aug 15, 2021 10:12 am
I have put a "surplus" IR receiver onto a tiny socket from my junk bag (removed from a stb or router of some description or other): see pcture; note how I have crossed the pins successfully.
73 de andy g0sfj
F1CJN_alain
Post by F1CJN_alain » Sun Aug 15, 2021 11:06 am
I am using the same on my Ryde from and old tuner.
It runs perfectly with a Samsung remote
Best 73s
Alain F1CJN
