SPG advice for old ccu operation
Hi Guys ,my first post so a little about myself ; Broadcast Engineer for nearly 30 years , operated and maintained various camera channels ; EMI 2001/1 , LDK3/pc60/pc80 , Link 110/120 ,Ikegami HL79D/E Sony M7's and modern widescreen HD units.
I'm planning on restoring an EMI 2001/1 channel back to full working order , the first camera type I was employed to use in the early 1980's.
It's going to be stand alone so I guess i'll need a source of line drive , etc .
It's quite a while since I had to keep 4 of them running in our studio (1991) so can anyone recommend a SPG to lookout for that I will need , or a modern fix to get it scanning again ?
All suggestions appreciated .
Many thanks for your time
Pete GW6SIX
Pete GW6SIX
Re: SPG advice for old ccu operation
I guess the only source of an SPG would be:
http://www.ebay.co.uk or
http://www.tvbay.co.uk
You can still buy brand new SPG's but at a price.
Good luck with your project.
Dave.
Dave.
Hi Pete,
following on from Dave's recommendation:
http://tinyurl.com/ebaypalspg
...the starting price is approximately 1/10th of the cost listed elsewhere.
73 de Darren
G7LWT
73 de Darren
G7LWT
Thanks for the advice , most modern spgs are sdi out and i'm looking for h and v drive , mixed syncs and camera blanking.
Courtyard still make one 490 model , not sure of price yet.
The small item suggested is b and b with 5 similar outputs.
Still hunting.
Regards
73's
Pete
GW6SIX
Still hunting.
Regards
73's
Pete
GW6SIX
Hello Pete,
There are a good number of PAL SPGs about surplus, they just need tracing down. A good one to go for is the blue "Seltec" 2U high one, it has the option for all 4 monochrome pulses (the board is usually in the crate) and it is very menderable if it goes wrong.
You could always build one, if you trawl back through the older CQ-TVs you will find several SPG designs.
Good luck with the EMI 2001/1, I would be interested to know how you get on.
73s Brian G8GQS
http://www.tvcameramuseum.org
73s Brian G8GQS
Many thanks for the reply Brian , since my last post I have aquired a couple of nearly complete 2u blue seltech 110ps !
Got one to work fine.
Feeding all the correct pulses into the ccu now and the scan failure warning light in the camera head has extinguished : )
Still got a few issues , working through them as time allows.
Major one is the camera head pulse board pulling down the +_18v camera supplies.
Luckily got all the manuals and also managed to borrow an extender board- almost had to make one .... : ))
Regards
Pete
Regards
Pete
