New Graphics Software to Generate Mpeg-TS Streams
sv8rv
Re: New Graphics Software to Generate Mpeg-TS Streams
Post by sv8rv » Fri May 07, 2021 3:22 pm
Any good news for the New Graphics Software?
73 de SV8RV
F1EJP
Post by F1EJP » Fri May 07, 2021 9:09 pm
Hello
very soon now!
to wait here is the documentation
73 to all
Dominique F1EJP
FreeStreamCoder-en.pdf
(938.7 KiB) Downloaded 625 times
G8KWR
Post by G8KWR » Sat May 08, 2021 4:04 pm
Hi Dominique, will the new software allow for streams up to 4.167 M/symbols and FEC 1/2, which is the configuration of my local repeater?
Roger
F1EJP
Post by F1EJP » Sun May 09, 2021 7:47 am
Hello Roger
SR from 25 Ks to 4 Ms is ok for you ?
Dominique F1EJP
Post by g0mjw » Sun May 09, 2021 9:02 am
Quite a few very old repeaters use MPEG2 and 4167kb/s QPSK DVB-S. Might be worth allowing a little more than 4Mb/s
G8KWR
Post by G8KWR » Sun May 09, 2021 11:14 am
Thanks for the reply Dominique.
As G0MJW has said, a number of older repeaters, including my local repeater (GB3UD) uses 4.167 M/s. If you have the opportunity to add that, it would be great. As someone relatively new to DATV, FFMPEG drives me crazy, so I am really looking forward to trying your program.
Roger
F1EJP
Post by F1EJP » Mon May 10, 2021 1:32 pm
hello G8KWR
Thank you for the explanations.
I will add SR 4167 in next version.
For me the speeds tested higher than 1.5M do not work correctly with the INTEL encoder and crashes on my laptop but the results are very good on my pc with NVIDIA
73 Dominique F1EJP
G8KWR
Post by G8KWR » Fri May 28, 2021 5:37 pm
Hello Dominique
I just wondered how your next version (with support for 4.167 MSymbols) was progressing.
Thank you for the work you are doing
Roger - G8KWR
G8KWR
Post by G8KWR » Sun Jun 27, 2021 2:07 pm
FreeStreamCoder V02.44 - An excellent piece of software Dominique, and you have obviously put a lot of effort and functionality into it, and thank you for adding 4.167 M/S.
Would there be any chance of adding MPEG2, in addition to the H.264/H.265 protocols to complete the flexibility you have built in, as there still a number of repeaters that are using it?
Thank you very much.
Roger - G8KWR
