Watching the BATC streamer on VLC
DL1BJV
Re: Watching the BATC streamer on VLC
Post by DL1BJV » Thu Mar 18, 2021 4:11 pm
Hello John,
thanks for the two very good BATC Streamer / Quad viewer files, all working perfectly here.
I am using the following minitiounerConfig.ini UDP TS IP's :
232.0.0.12:9999 preset for the Scan & Tune Version and
230.0.0.10:10000 preset for the MT V1.0.1.0r beta.
Is it possible to save these IP's as the 'Default' 230.0.0.1:1234 always comes up after a restart.
would be 'nice to have' but not really all that important as it could be changed in the in the Config.ini file.
Wolfgang.
G7JTT
Post by G7JTT » Thu Mar 18, 2021 7:28 pm
Hi Wolfgang yes I'll add that in the next few days hopefully.
73 John
G7JTT
Post by G7JTT » Fri Mar 19, 2021 6:24 pm
Here you go Wolfgang just edit the IPAddress.txt file if you need more addresses.
73 John
VLC-Quadv0.3..zip
(70.22 KiB) Downloaded 749 times
DL1BJV
Post by DL1BJV » Fri Mar 19, 2021 8:33 pm
Hi John,
thankyou very much, that was a very fast response indeed.
Just tested it and everything is working perfectly.
I was very surprised to see that you have even added the MiniTouner UDP TS Addresses which I am useing.
Thanks for your excellent work.
Wolfgang.
G8HKN
Post by G8HKN » Sat Mar 20, 2021 3:34 pm
Thought I would try opening two Quads and overlapping
Screenshot (10).png (774.81 KiB) Viewed 13736 times
Thanks for your work John How about a six way one without The minitiouner ?
Roger G8HKN.
Post by g8gtz » Sun Mar 21, 2021 9:09 am
FYI - I've set up a wiki page that you can point people to when they complain about the 15 second stream delay.
https://wiki.batc.org.uk/Watching_the_streamer_with_VLC
Plus there's an article in the CQ-TV about to be published.
G0MXW
Post by G0MXW » Mon Mar 22, 2021 12:18 pm
Having problem with both streamviewer and VLC-quad. Both when started just give a spinning wheel for about 5 secs then nothing, no error, no start. Tried as local user and administrator, same result. Windows 10 pro, net framework 4.8 installed. Any suggestions ??
Dave G0MXW
M0IVJ
Post by M0IVJ » Tue Mar 23, 2021 9:02 am
I'm having the same problem with the VLC stream viewers on Windows 10. I ran the exe in Visual studio to see if I could track down the fault, and get the following Debug message.
System.Runtime.InteropServices.COMException
HResult=0x80040154
Message=Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
Source=System.Windows.Forms
StackTrace:
at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid)
at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at VLC_Quad.Form1.InitializeComponent() in C:\Users\hilux\source\repos\VLC-Quad\Form1.Designer.cs:line 262
at VLC_Quad.Form1..ctor() in C:\Users\hilux\source\repos\VLC-Quad\Form1.cs:line 21
at VLC_Quad.Program.Main() in C:\Users\hilux\source\repos\VLC-Quad\Program.cs:line 19
Hope this helps
John M0IVJ
G7JTT
Post by G7JTT » Tue Mar 23, 2021 11:13 am
Sorry as stated in the first post I'm very new to visual studio, only thing that springs to mind is firewall. When first run it should (at least with windows defender) ask for permission to access the network. So one check would be to see if it's a antivirus/firewall issue. When I got my new laptop it had McAfee installed, I soon uninstalled it after it stop lots of apps connecting to my network.
Hope this helps, John G7JTT
G7JTT
Post by G7JTT » Wed Mar 24, 2021 6:40 am
One other thought, I take it all files were extracted to the same directory and the exe file ran from there ? I've tried it on Windows 10 home, Windows 7 and 8.1 and it works on all of them. So sorry not sure why it doesn't work on either of your PC's.
73 John G7JTT
Return to “Streaming”
