Script for generate IPTV with OBS + FFMPEG + NVIDIA card OR cpu INTEL
F1EJP
Re: Script for generate IPTV with OBS + FFMPEG + NVIDIA card
Post by F1EJP » Thu Mar 04, 2021 5:47 pm
new version with small correction and improvement
(thanks to Dave G8GKQ)
operating limit :
- en 66KS/s mode QPSK FEC 3/5
- en 35KS/s mode 8QPSK FEC 3/4
- en 25 KS/s mode 16QPSK FEC 3/4
73 good tests
F1EJP
Dominique
IPTV-F1EJP-OBS-v01.03.zip
(3.61 KiB) Downloaded 682 times
G7JTT
Post by G7JTT » Fri Mar 05, 2021 6:47 am
Again thanks for sharing, it's working a treat 👍
73 de G7JTT John
Post by G8GKQ » Fri Mar 05, 2021 8:48 pm
For those of you coming to this having not used OBS before, you need to load an additional plugin to make the virtual camera work (with audio) in OBS.
So make sure that you have the latest version of OBS (currently 26.1.1). Then go to https://github.com/Fenrirthviti/obs-vir ... m/releases and then download the installer for obs-virtualcam 2.0.5. Run the installer, close OBS, restart OBS and then go to Tools, VirtualCam, and make sure that Autostart is ticked. Click start.
Then you can run Dominique's script and it will pick up the video and audio from OBS.
Testing on QO-100 this evening, I was really impressed. Less than 2 seconds round trip delay using the graphics processor built into the CPU in my Intel laptop, Thanks to Colin G4EML for flagging up that capability! And thanks to John G7JTT for helping me with OBS.
F1EJP
Post by F1EJP » Sat Mar 06, 2021 1:31 am
With the idea of ​​G4EML I adapted the script.
Here is another new "beta" version with bug fixing and choice of harware.
You have to edit the start of the script to choose whether to code with an NVIDIA gpu or an recent INTEL CPU
The compression is a little more efficient with NVIDIA at very low speed but the results are also good with INTEL.
Thank all for you for your tests.
Dominique
IPTV-F1EJP-OBS-v01.15.zip
(3.73 KiB) Downloaded 605 times
g4eml
Post by g4eml » Sat Mar 06, 2021 10:04 am
Thanks Dominique, that is very useful.
Your script works equally well when sending directly to a Pluto. I just need to change the IP address to 192.168.2.1:8282
Colin.
sv8rv
Post by sv8rv » Sat Mar 06, 2021 12:48 pm
Thanks Dominique for your script.
I have modified it for Vmix external output ...talking to lan pluto or to portsdown.
Tested also on sr35 and sr25. Video was ok but audio had some distortion on these sample rates.
73 de SV8RV
vu3obr
Post by vu3obr » Sun Mar 07, 2021 1:37 am
Thanks Dominique for your script,
Tested with Portsdown 4 and 2020 with LimeSDR USB SR25,SR35 Audio is distortion. Also tested with Pluto UDP same result with low SR.
Again thanks for sharing.
VU3OBR
Saro
F1EJP
Post by F1EJP » Sun Mar 07, 2021 10:33 pm
Hello all,
New version 1.16 for test !
new version with smalls improvements:
> audio improved at very low bitrate and in stereo from 250KS / s
F1EJP
Dominique
IPTV-F1EJP-OBS-v01.16.zip
(3.76 KiB) Downloaded 569 times
G7JTT
Re: Script for generate IPTV with OBS + FFMPEG + NVIDIA card OR cpu INTEL
Post by G7JTT » Mon Mar 08, 2021 5:55 am
Wow just keeps getting better and better 👍
73 John
roland_F8CHK
Post by roland_F8CHK » Tue Mar 09, 2021 10:38 am
Hi all,
Following Dominique idea, I wrote a windows app to configure ffmpeg. This has not been intensevely tested...you may have to load a Microsoft dot net core to run it on your computer.
Let me know if it is usable!
73,
Roland F8CHK
conf_ffmpeg.zip
(116.36 KiB) Downloaded 708 times
