I've modified a new Pluto so the ground mod and 0.5ppm TCXO are fitted pictured. The Pluto did a SATSAGEN spectrum analyser and tracking generator sweep on a coax cable from 50MHz to 6GHz just fine with DATV firmware. It transmits a signal in FM with the Langstone that shows up on my spectrum analyser on e.g 2m, 70cm and 23 cm bands. The DATV firmware info page shows up no bother. All attempts to produce a DATV signal in Pluto output in Portsdown 4 have come to nought.
Can one load DATV firmware on my second Pluto which is unaltered and then go back to AD firmware later? I've no idea what normal behaviour is like for the Pluto option.
David M0YDH
