Low band contest - Sept 19th and 20th - input please
M0SKM
Re: Low band contest - Sept 19th and 20th - input please
Post by M0SKM » Tue Sep 15, 2020 11:54 am
Unfortunately my van has an electrical fault so I can't get out, a shame because I have all the portable kit for both bands. However I talked to Arthur G4CPE and he will be active on 4m Saturday, there's also a chance he will do 6m if a test goes well. Arthur has a good path to Walbury Hill.
If I transmit 4 and 6m on a rubber duck Arthur will receive me running Pluto barefoot, so that's his first contact sorted.
73 Steve
G4FRE
Post by G4FRE » Fri Sep 18, 2020 9:03 am
Now this weeks other 4 contests are out of the way, time to think about the weekend!
G4FRE/P will be active Saturday afternoon on 50 and 70MHz from Titterstone Clee IO82QJ. High 4m noise level from the radio station preclude the use of IO82LB nowadays
On 50MHz I will have 150W on 70MHz 20W.
Portsdown 2019+modified G4DDK Nacton 437/51 and 437/71MHz transverters
Antenna is a Innovantennas 4+4 ele which I bought in 2014! As others have discovered, it is not a "quickly buildable in the field" antenna, but it is easier to get into the air than two monoband 5 element yagis
I will have a vertical antenna for 2m fm talkback along with zello (ATV south) and 07941541592
G4FRE
g8vpg
Post by g8vpg » Fri Sep 18, 2020 3:18 pm
I am confirming that I will be active from 1.00pm local time tomorrow, Saturday 19 September, from IO81QF, the Mendip Hills, Somerset. I will have 4m DATV only, about 20W to a 3 element beam. This site has a good take off in all directions. Talk back 144.750MHz FM horizontal, Zello ATV South or 073 78 348 455.
73 Shaun.
Post by radiogareth » Fri Sep 18, 2020 4:42 pm
Just re-confirming my activity, TX on 6 & 4 although my RX is somewhat flakey (software issues). Worst case will be DVB into a RTL Dongle on my Portsdown 2019.....
Talkback H or V or call me 07905 927230 IO91Xh WOldingham Surrey.
Hope to 'see' you.....
Post by g8gtz » Fri Sep 18, 2020 5:12 pm
Reconfirming my plans:
Walbury IO91GI from 1pm Saturday.
50MHz - 20 watts but no filter on rx despite working all day on it.
70MHz - 20 watts with OK rx.
144.750 vertical, dxspot maybe, zello maybe and 07881914287
Post by g0mjw » Fri Sep 18, 2020 7:14 pm
I will try to come on from home IO91IO with 6/4/2m. 6m might be a bit of a challenge but we will see!
Post by M0DTS » Fri Sep 18, 2020 8:02 pm
I will be on from IO94JF.
4m: 6el - 10W
No 6m, just not enough time to get that sorted, not portable ready yet!
T/B Zello / 144.750 / Dxspot.
Post by g0mjw » Fri Sep 18, 2020 9:29 pm
Some info on what I plan to use.
I have 6m TX via my MK1 Portsdown and 4m PA seems to work OK on 6m. At least to 5W or so. You might try that. The rub is my 4m pre-amp which has nice tight filtering doesn't work on 6m so please remind me if I can't receive you that I need to bypass it!
4m is currently using the Portsdown too so its DVB-S only. I have up to 10W but need to respect the EIRP limit.
6/4m is a dual band beam 5 elements on 4m and 4 elements on 6m
2m will be Portsdown Lime with 17 element Tonna. About 5W RF.
Receive with Minitioune or Portsdown
The 144.750 shares the 2m antenna so probably Zello talkback or 70cms.
Post by g8gtz » Sat Sep 19, 2020 7:58 am
Due to a major disaster yesterday (my wide band PA ceased to draw current) I will not have 146MHz.
I will however, due a request from Gareth, have 5.6 / 5.7GHz.....
Talk later Noel
g8vpg
Post by g8vpg » Sat Sep 19, 2020 8:59 am
I have packed my 5.6GHz kit aswell, wideband FM, not digital though. Leaving in an hour.
73 Shaun.
