Latest build: after reboot frozen screen
Re: Latest build: after reboot frozen screen
Colin,
In my first post I already listed the ps -ax Langstone services, here are those from the Langstone only build:
700 tty1 S+ 0:00 /bin/bash /home/pi/Langstone/run
757 tty1 Sl+ 0:41 python /home/pi/Langstone/Lang_RX.py
762 tty1 S+ 0:00 /home/pi/Langstone/GUI
So I'm missing the Lang_TX.py
./ stop and ps -ax: all 3 above mentioned services are gone
pi@raspberrypi:~/Langstone $ python Lang_TX.py &
[2] 860
pi@raspberrypi:~/Langstone $ ERROR: Open unlocked: -16
Traceback (most recent call last):
File "Lang_TX.py", line 227, in <module>
main()
File "Lang_TX.py", line 219, in main
tb = top_block_cls()
File "Lang_TX.py", line 49, in __init__
self.pluto_sink_0 = iio.pluto_sink('ip:pluto.local', 1000000000, 528000, 2000000, 0x800, False, 0, '', True)
File "/usr/lib/python2.7/dist-packages/gnuradio/iio/iio_pluto_sink_swig.py", line 126, in make
return _iio_pluto_sink_swig.pluto_sink_make(*args, **kwargs)
RuntimeError: Unable to create buffer: -16
pi@raspberrypi:~/Langstone $ python Lang_RX.py &
[2] 861
ps -ax: only 871 pts/0 S 0:00 python Lang_RX.py is listed
pi@raspberrypi:~/Langstone $ ./GUI &
[2] 876
pi@raspberrypi:~/Langstone $ Warning: the blks2.selector block is deprecated.
gr::log :INFO: audio source - Audio sink arch: alsa
len(audio_taps) = 231
Unable to refill buffer: Connection timed out
ps -ax: only Lang_RX.py and ./GUI are listed
It seems I have a problem with the Lang_TX.py task not starting due an error.
73 Freddy
[2] 860
main()
[2] 861
[2] 876
73 Freddy
73 de ON1AVO
Freddy
Freddy
Hi Freddy,
you have taken the OS (see attachment) as the basis for the installation.
If this does not work despite a correct installation, then the best thing to do is to use a new SD card.
For me it works without any problems.
- PI-OS-Lite.jpg (42.85 KiB) Viewed 7929 times
I always have crazy ideas.
Please don't be surprised.
Thomas,
Yes this is the version I use to build the SD card.
I tried already 3 different 16GB class 10 SD cards of different vendors: Sandisk, Kingston and Transcend.
73 Freddy
73 Freddy
73 de ON1AVO
Freddy
Freddy
SDR Console does not work without it so it may well be relevant.
Hi Freddy,
I just looked at the picture of you. With such a USB sound card it doesn't work for me either.
I have the following USB sound card: https://www.rasppishop.de/USB-Soundkarte-Soundadapter
Hi Freddy
Is that the same sound card as you mentioned in your first post?
Doesn't look like it to me - but I may be wrong.
- Bus 001 Device 004: ID 1b3f:2008 Generalplus Technology Inc.Dave
Dave,
Yes it is.
On https://wiki.microwavers.org.uk/Langsto ... io_Adapter it is described as a working one, so it should be OK.
73 Freddy
Yes it is.
73 Freddy
73 de ON1AVO
Freddy
Freddy
Freddy,
Yes your problem is that for some reason Lang_TX.py is not starting. Nothing has changed in that file for some time and my tests yesterday show that it is still working OK. If you have done a fresh build as I did then it should behave the same.
So you need to find out why it is not working on your system.
The error message seems to be coming from the iio library which handles the communication to the Pluto. Like most error messages it is not much help.
One thought, is your Ethernet network on a different subnet? If it was also on 192.168.2.x it might cause a problem as it would clash with the Pluto.
One other possibility is that the ‘For the Brave’ firmware is causing some problem. I don’t think that it should as I am fairly sure that is what I am using. If you still have the original firmware it might be worth reloading that just in case.
Colin.
Colin.
I will just re-iterate, it you do not have the force compliant box checked in Beta for the Brave, the Pluto does odd things with SDR Console and it might be the same problem here.
