VMIX Streaming
glen_turner2002
VMIX Streaming
Post by glen_turner2002 » Wed Jun 17, 2020 12:41 pm
Hi, I've decided to have another go at streaming to the BATC but Vmix has stopped working. i saw the details have changed to after correcting the info it still doesn't work and i'm now lost as to what goes where as I've trying everything around.
Destination = Custom RTMP Server
URL = rtmp://rtmp.batc.org.uk/live/streamname-G7MNP
Stream Name or Key = (I put the key from my account dashboard)
My responce from Vmix
****** = My Password (correct)
###### = My Key (correct)
FFMPEG1.Exited
Streaming
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
rtmp://G7MNP:******@rtmp.batc.org.uk/live/streamname-g7mnp/######: Input/output error
Can anyone tell me what I've done wrong?
Thanks,
Glen...
M0SKM
Re: VMIX Streaming
Post by M0SKM » Wed Jun 17, 2020 1:49 pm
Hello Glen
You don't need streamname, your callsign is the stream name. Try this.
G7MNP-#####
The second line goes where vMix asks for stream name or key.
Hashes are your key characters.
Steve
glen_turner2002
Re: VMIX Streaming
Post by glen_turner2002 » Wed Jun 17, 2020 2:25 pm
Hi Steve,
Thanks for the reply, Something has changed but its still not streaming.
FFMPEG1.Exited
Streaming
rtmp://G7MNP:******@rtmp.batc.org.uk/live/g7mnp/g7mnp-######: Input/output error
ffmpeg started on 2020-06-17 at 15:21:41
Report written to "C:\ProgramData\vMix\streaming\streaming1 20200617-152141.log"
ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc
libavutil 55. 2.100 / 55. 2.100
libavcodec 57. 3.100 / 57. 3.100
libavformat 57. 2.100 / 57. 2.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 9.100 / 6. 9.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 166149.585000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 25 tbr, 10000k tbn, 25 tbc
[tcp @ 008eeea0] TCP Buffer has been set to 3990528 bytes
M0SKM
Re: VMIX Streaming
Post by M0SKM » Wed Jun 17, 2020 3:22 pm
This is the entry in my vMix. Is this the same view you have? Mine is the full paid HD version.
glen_turner2002
Re: VMIX Streaming
Post by glen_turner2002 » Wed Jun 17, 2020 3:30 pm
That's exactly what I have and the streamer used to work fine. I've put it to exactly like you said and I've also got the paid for version.
At least with your help I've got further. :) so thanks for that.
Re: VMIX Streaming
Post by G8GKQ » Wed Jun 17, 2020 4:12 pm
Glen
You have 2 items double-entered. The last line of the ffmpeg error report says that it is trying to stream to:
The address it should be trying to stream to is:
rtmp://rtmp.batc.org.uk/live/g7mnp-######
Details here on the Wiki: https://wiki.batc.org.uk/Configuring_yo ... _input_URL
glen_turner2002
Re: VMIX Streaming
Post by glen_turner2002 » Wed Jun 17, 2020 4:41 pm
Thank you for your reply and its now working....
Its easy when you know how, What i don't understand is it worked for a long time then stopped.
Anyhow its all good now,
Thank You Dave and Steve!
Regards, Glen
M0SKM
Re: VMIX Streaming
Post by M0SKM » Wed Jun 17, 2020 5:55 pm
Could it simply have stopped working due to a key (password) change?
Since I first took a stream my key has changed at least four times, not of my doing; it changes in the member control panel.
Steve
glen_turner2002
Re: VMIX Streaming
Post by glen_turner2002 » Wed Jun 17, 2020 7:39 pm
Hi Steve,
I think originally that was the case but over time and me changing things i got lost. but its all good now, Thanks for your help.
now i want to see if i can send the UDP stream from Mini Tiouner into Vmix so i can stream it. So far I'm not having much luck i don't know if its possible?
Glen
glen_turner2002
Re: VMIX Streaming
Hi Steve,
Glen
Return to “Streaming”
