Langstone - Portsdown Convergence
Re: Langstone - Portsdown Convergence
Post by G8GKQ » Thu May 28, 2020 10:12 pm
Hi Terry
The IPTS Monitor does seem to have a problem. I'll probably change it to use VLC when I fix it. Thanks for reporting the issue.
Post by G8GKQ » Mon Jun 01, 2020 2:11 pm
Hi Terry
I have just done some more testing and the IPTS Monitor worked this time! It does take a while to start up, so try leaving it 30 seconds or so. In the longer term, I will look at replacing it with a VLC-based solution, but there are a few higher priority things that I want to sort out first.
G1LPS Terry
Post by G1LPS Terry » Mon Jun 01, 2020 5:12 pm
Apologies Dave
Yes it works perfect.
Forgetful moment on my account.
Didn't set the IP for the pi4 build in the script :oops: :oops:
Terry
