Langstone Update
g4eml
Re: Langstone Update
Post by g4eml » Tue May 12, 2020 3:42 pm
Hi Malcolm.
The file is /boot/config.txt
Remove or comment out the line
lcd_rotate=2
This is added by default when you do an install as I thought most displays needed it. That may not be the case.
Colin.
g0uhy
Post by g0uhy » Tue May 12, 2020 3:46 pm
Hi Colin,
yes that's the one...hi. Many thanks.
Malcolm
i2NDT
Post by i2NDT » Tue May 12, 2020 5:24 pm
the new audio dongle arrived yesterday!
now it seems it's OK!
generated a 144.870 FM signal (1kHz tone, 3 kHz deviation) and received perfectly well: the tone is clear now.
attached a picture of the screen: is the waterfall correct?
Claudio
PS
also upgraded to the last version.
i2NDT Claudio
Dalmine, Italia
g4eml
Post by g4eml » Tue May 12, 2020 9:39 pm
Hi Claudio,
That is good news.
Yes, the waterfall is correct for a constant FM tone.
Colin.
Post by radiogareth » Wed May 13, 2020 10:58 am
Waiting on a couple (1 each) of the Pluto PTT boards from the BATC shop I went looking for the small reed relay used on one of them. eBay has them at 1/2 Farnell price , or better, including the DPNO version https://www.ebay.co.uk/itm/Hamlin-HE722 ... SwFV1bKmuR
Looking at the PCB (not got one in hand yet) the package will fit the board, but are the spare pads isolated or already commoned (i.e. could be joined, then you have double the current capability).
I've also got possibly 100+ Pickering branded mercury wetted relays off some switcher unit that I bought for the box (£1 :-) and although they come off a logic board they only just pull in on 5 volts, so possibly not reliable. Shame.
Which to order......
g0uhy
Post by g0uhy » Wed May 13, 2020 12:34 pm
Hi Gareth,
got mine from CPC. Search for SW03255, 95p each + the usual VAT.
Malcolm G0UHY
g4eml
Post by g4eml » Wed May 13, 2020 2:01 pm
Note that at the moment the Langstone does not control the Pluto digital outputs, so the Pluto PTT board will not work. Currently the PTT output and band select bits are only available on the Raspberry Pi GPIO pins.
If I can find out how to control the Pluto outputs I will add it to the code.
Colin.
Post by g8gtz » Wed May 13, 2020 3:26 pm
Using the Pi GPIO of course means you can use the P'down 4 and 8 way RF switch and PTT steering.
Or even make it ready for some interesting developments in the future :D
https://twitter.com/davegkq/status/1260 ... 35266?s=20
Post by g0mjw » Wed May 13, 2020 3:51 pm
Make sure you order one with the back EMF suppression diode integrated or add a diode to the pads included for the purpose, otherwise it's a one shot device.
g4eml
Post by g4eml » Wed May 13, 2020 3:53 pm
Actually it won’t be easy to add control of the Pluto GPIO pins. It looks like they can’t be controlled over the network using the standard Libiio driver. Only by a program actually running on the Pluto.
