Oscar 100 Live Tune software
Re: Oscar 100 Live Tune software
Post by M0DTS » Tue Feb 25, 2020 10:34 pm
cool, i had a go but i could not get it to run under mono on my machine.
probably some missing libraries i have not installed!
Post by M0DTS » Thu Mar 26, 2020 10:22 am
A new version has been uploaded to the batc wiki which corrects for the frequency offset and the new DATV bandplan on OQ-100.
Versions older than 0.9b will no longer work correctly.
Download the new version here:
https://wiki.batc.org.uk/QO100_Live_Tune
G7JTT
Post by G7JTT » Thu Mar 26, 2020 11:34 am
Many thanks Rob for the Quick update, very much appreciated 👍
cheers John G7JTT
AdrianH
Post by AdrianH » Thu Mar 26, 2020 11:53 am
And a big thanks from me, new version also running OK under Linux in mono.
Must admit I was looking for the start frequency in the bandplan.xml file. That may be a consideration to save you incase of future updates, although I would doubt if any more room left on the transponder.
Adrian
Post by M0DTS » Fri Mar 27, 2020 9:12 am
Excellent.
I had thought about adding it to the bandplan settings and may do-so in a future version, but at the same time i would probably add the span too but that would need a bit more work.
Hopefully it will stay as-is for a while now :-)
