At the CATS Bazaar in 2018 I bought a pair of 'VHF pager amps'' mainly for the dual mosfet and heatsinks/fans that came with them. CLoser inspection revealed that each one had a CA2832C broadband amplifier module as part of the driver chain. https://www.digchip.com/datasheets/part ... 2C-pdf.php Trying to use the amp 'as-was' for DATV showed something was causing instability, so I removed the significant gain block and used a bit less drive. It worked, but not as well as my cheap Chinese 'VHF amp using a MRF186. However, with the advent of Pluto DATV and of course Lime derived signals, operation on 50/70/144 is relatively simple (no 50 for the Pluto).
About time I reused the handy little gain block. Unconditionally stable the data sheet says, +35dB 1-200 MHz too. I was planning on putting up a tinplate divider between input and output, but it does indeed seem to be stable without one. The 28 volts operating voltage is derived from an eBay XL6009 step-up converter board, available at £5.40 for 4 delivered. Additional filtering at the output was added to keep the nasties out of the amp. The heat sink came from a defunct 5.8GHz drone transmitter along with the little fan, running off a sub regulator at 3.3 volts. Just about keeps things cool as the amp is I suspect heavily biased for linear operation. It certainly produced a clean signal when driven from my MFJ as a test. A couple of SMA sockets, some standoffs and a grommet, along with a nice blue LED and on/off switch complete the gain block. I'll try feeding it with some DATV tomorrow as I check over the VHF contingent of my station.
The joys of surplus....
Jump to
- Forum Admin
- ↳ Announcements
- ↳ Feedback
- ATV General Discussion
- ↳ Getting Started?
- ↳ General ATV Discussion
- ↳ DATV - Digital ATV
- ↳ ARISS HamTV
- ↳ LimeSDR Mini
- ↳ CQ-TV, The BATC Magazine
- ↳ BATC Bursary Grants
- ↳ Spectrum matters
- ↳ Streaming
- ↳ EMF Compliance
- ↳ Narrow Band DATV (RB-TV)
- ↳ DXSpot.TV
- ↳ Deutschsprachiges Forum
- ↳ Events
- ↳ DigiThin
- ↳ DigiLite
- ↳ BATC DTX1
- ↳ CaribouLite RPi Hat
- Adverts
- ↳ For Sale
- ↳ Wanted
- ↳ BATC Shop
- ATV Repeaters
- ↳ UK ATV Repeaters
- ↳ GB3BH
- ↳ GB3CZ
- ↳ GB3DK
- ↳ GB3EN
- ↳ GB3ET
- ↳ GB3EY
- ↳ GB3FB
- ↳ GB3FT
- ↳ GB3FW
- ↳ GB3FY
- ↳ GB3GG
- ↳ GB3GV
- ↳ GB3GW
- ↳ GB3HV
- ↳ GB3IF
- ↳ GB3IT
- ↳ GB3IV
- ↳ GB3JT
- ↳ GB3KM
- ↳ GB3LO
- ↳ GB3LX
- ↳ GB3MV
- ↳ GB3NQ
- ↳ GB3NV
- ↳ GB3PV
- ↳ GB3RT
- ↳ GB3RV
- ↳ GB3SQ
- ↳ GB3TG
- ↳ GB3TM
- ↳ GB3TN
- ↳ GB3TT
- ↳ GB3TV
- ↳ GB3TZ
- ↳ GB3UD
- ↳ GB3VR
- ↳ GB3UT
- ↳ GB3VL
- ↳ GB3VV
- ↳ GB3VX
- ↳ GB3WV
- ↳ GB3YT
- ↳ GB3ZZ
- ↳ Internet-only Repeaters
- ↳ IO91LC
- ↳ IO91WN
- ↳ IO92GQ
- ↳ Overseas ATV Repeaters
- Archive
- ↳ GB3AT
- ↳ GB3FT
- ↳ GB3FV
- ↳ GB3CT
- ↳ GB3AD
- ↳ GB3BG
- ↳ GB3DH
- ↳ GB3DJ
- ↳ GB3KT
- ↳ GB3NV
- ↳ GB3OT
- ↳ GB3PT
- ↳ GB3TB
- ↳ GB3TX
- ↳ GB3VW
- ↳ GB3XG
- ↳ GB3XT
- ↳ GB3XV
- ↳ GB3XY
- ↳ GB3YT
- ↳ GB3YX
- ↳ For Sale Ads Archive
- ↳ Wanted Ads Archive
- ↳ CAT 16 and BGM 2016
- ↳ CAT 17
- ↳ CAT18
- ↳ Mini-Conventions in 2019
