Second stream add-on PCB: hardware question
Terry-G0EZY
Post by Terry-G0EZY » Mon Sep 23, 2019 2:23 pm
I am collecting the parts for the Dual Channel output for the BATC V2 Minitiouner described in the CQ-TV264 article. Please could anyone let me know the Digi-Key (or equivalent) part number for the male 16 way (2 x 8) plug that mates with the A33163-ND female plug on the main board? There are several options on the D-K website but none that seems right for the job. The 487223-3-ND looks close to what has used but D-K supplies the pins separately and the ones shown look intended for cable connection rather than direct thru-hole soldering to the PCB.
Terry G0EZY
Re: Second stream add-on PCB: hardware question
Post by g0mjw » Tue Sep 24, 2019 9:56 am
I assume you mean this
I went for this item SAM11093-ND but you can choose others.
Height clearance is important and a large fuse holder or a tall capacitor might be a problem. This is a plug-in that was not envisaged at the time the V2 board was designed.
Terry-G0EZY
Post by Terry-G0EZY » Sun Sep 29, 2019 9:24 pm
Thanks for forum and direct replies. Exactly what I needed!
73 Terry
