GTMEDIA V8 Finder (V73-HD) Able to receive QO-100 Beacon.
Picked one of these up from eBay a couple of weeks ago, this model is identifiable by the Gold front case, I have no idea if the older Yellow V71-HD V8 finder can do this, I did have one a while back but QO-100 hadn't launched then.
Was just aligning one of my dishes and thought i'd see if this thing would work with the QO-100 Beacon, indeed it does and tunes outside the normal domestic satellite range. I will have to see if it will tune in lower SR's. The lowest SR you can set through the menu is 1000, but I will have a play with the channel/satellite editing software and try and manually add a SR of 333 and see if it accepts it that way.
Cheap useful tool for alignment and an added bonus you can align to the QO-100 Beacon.
https://youtu.be/Dg1GTgU3l3s
Re: GTMEDIA V8 Finder (V73-HD) Able to receive QO-100 Beacon.
Received as low as 1000KS, Device does not allow you to enter anything below 1000KS, currently messing around with the chipset software to see if I can manually add a "Channel" Or edit config settings to allow lower Symbol Rates.
CT1BYM rx'd @ 1000KS, Pictures attached.
- 20190618_170606.jpg (225.9 KiB) Viewed 43613 times
- 20190618_170600.jpg (245.29 KiB) Viewed 43613 times
Try 70cm , it works on mine sr 1k.
There are some fake GTmedia ones around even the gold ones see:
https://www.freesat.cn/forum/viewtopic. ... 0&start=50
Did anyone try the YELLOW one ?
Just been experimenting with the yellow V8 finder and I have managed to get the QO-100 Beacon on 10491.000 and 1.5 ms/s.
To program the v8 add a new satellite then add a new transponder. Then entering the frequency will not work if the LNB is set at 9750 as it will reply not in range.
To get around this I changed the LNB to universal 5150-11475 - then enter the frequency after saving the configuration.
This will enable you to set a frequency of 10491 mhz and save it.
Next go back into the transponder and move to the second menu change the LNB back to 9750.
Save again and then do a search using blue button and A71A should appear!
i am using a 80cm dish and getting 63% strength and 55% quality when no cloud in the way.
- IMG_20240224_131240.jpg (1.28 MiB) Viewed 27788 times
- IMG_20240224_131116.jpg (1.25 MiB) Viewed 27788 times
- IMG_20240224_130758.jpg (1.59 MiB) Viewed 27788 times
I tried this with the latest orange coloured iBravebox v9 Finder and it does not work because that universal lnb option is not available. Also, although it tunes 1500ks/s, it will not tune 1000ks/s.
73 Shaun.
73 Shaun.
Thanks for this cool tip and the step by step instruction! Works perfectly with mine V8.
vy 73 Rainer
vy 73 Rainer
Hi Folks,
Does anyone know if the
GT Media V8 Finder 2 Satellite Signal Meter
will receive QO-100 ?
Thank you,
Don
Thank you,
Don
No idea, but I expect it will receive other transponders on the same satellite if all you need to do is align the dish.
As Es´hail-2 is located at 25.8 East and all transponders there are MENA, a reception in Europe is not so easy.
Aligning the dish with BBC Arabic will lead to a slight mismatch, as the transponding sat is BADR 8 at 26.0E.
Rainer
Rainer
I did own one of those but found it a lot easier to use my Portsdown/bandviewer to find the NB beacons and then the WB, aided by a compass and a Lidl Inclinometer.
That it only did 1000ks and above, plus a not-obvious-to me method for entering the required data meant I sold it on.
I started with this and found it pretty quickly https://eshail.batc.org.uk/point/
