18v h power
M5TXJ
Re: 18v h power
Post by M5TXJ » Sun Apr 28, 2019 5:50 pm
Hi all,
I just added an EBay buck converter and a centre off dpdt switch into my Minitiouner, the switch simply puts 12v or 18v to the pcb pin that feeds lnb power to the NIM.
73 Dave.
2W0ODS
Re: 18v h power
Post by 2W0ODS » Sun Apr 28, 2019 7:04 pm
Hi all,
73 Dave.
I've never had any luck with those Buck converters, they seem to cause a lot of QRM, especially on the 2m band.
M5TXJ
Re: 18v h power
Post by M5TXJ » Sun Apr 28, 2019 7:17 pm
Don't need the buck converter on 2m, only for 18v, that's why it's on a centre off switch. Because the 12v feed is direct from the incoming supply it can also feed a preamp on 2m and 70cm, win win. I always add extra filtering to the converter too.
Don't forget the RT5047 is also a buck converter.
G4NRT
Re: 18v h power
Post by G4NRT » Wed Jul 03, 2019 7:13 am
Nick wrote:
Sun Apr 28, 2019 11:02 am
I just use a E-Bay buck converter to get the 18V. The 18V output is fed to a 12V regulator with didoes in the common connection to get the voltage to 13V. The Bias-T itself was obtained from E-Bay.
Nick - G4NKV
I really need one of these! The problem is that I no longer have the eyes or the manual security to build one myself. Can anyone direct me to a 'ready made' solution?
TiA and 73, David G4NRT
M0IVJ
Re: 18v h power
Post by M0IVJ » Thu Jul 04, 2019 7:56 am
Hi David, Richtek make an evaluation board (Digi-Key Part Number EVB_RT5047GSP-ND) that can be used with the Minitioune and controlled with the latest software. It’s expensive for what it is, but saves the eye strain.
73's John M0IVJ
G4NRT
Re: 18v h power
Post by G4NRT » Thu Jul 04, 2019 8:31 am
Thanks John. I shall check it out.
David G4NRT
G4KLB
Re: 18v h power
Post by G4KLB » Sat Jul 06, 2019 11:02 am
Working on a version that fits the standard V2 box ........ watch this space.
RT5047 T.jpg (911.61 KiB) Viewed 9123 times
RT5047 top.jpg (697.2 KiB) Viewed 9123 times
RT5047 btm.jpg (1.39 MiB) Viewed 9123 times
RT5047 i.jpg (845.72 KiB) Viewed 9123 times
This one is configured for testing the various options, more info to follow.
If all goes well should find the PCB in the BATC shop, some minor rework to make construction easier after testing is complete.
G4KLB
Re: 18v h power
Post by G4KLB » Mon Jul 29, 2019 2:43 pm
Almost ready with our version to fit the standard V2.0 case
(Someone forgot to specify blue boards on this prototype) :oops:
