DATV-Express Project
Re: DATV-Express Project
Group is the multicast group address.
Source is the source address of the UDP stream, if you want to accept anyone set it to 0.0.0.0
if source is set to zero it assunmes the group address is not a multicast address.
Interface is the IP address on your network of the interface you want to use on your current machine.
You will only see multiple interfaces if you have more than 1 hardware interface on your machine.
Clear as mud (I used the same expressions that are used in the MS example I stole the code from).
- Charles
- Charles
Morning Charles,
 ) I don't understood
Happy day, 73 Franck
						Sorry perharps my English is not perfect (google too.if you want to accept anyone set it to 0.0.0.0
When I press PTT, my queue starts 0 to finish at 100%, what is root cause for you?.Clear as mud
1) Setting it to 0.0.0.0 means it ignores the source address field.
2) Your transport stream bitrate level is too high and does not match the DATV-Express transmitted bitrate (I do no transcoding).
- Charles
- Charles
Charles, I have a problem to use UDP.
I have a batch file to genarate TS Stream on UDP/210.0.0.10:10000
When I control the flux on my lan with Wireshark, I can see TS flux from source to the correct destination .
But DATVExpress don't listen, I don't understand why, windows firewall is OK for Datvexpress and ffmpeg.
Can you help me please?
73 Franck
- udp.PNG (9.3 KiB) Viewed 6942 times
- udpshark.PNG (94.26 KiB) Viewed 6942 times
Just a quick report that Art WA8RMC received the latest batch of Serit NIM tuners on April 09.
He is now busy assembling the tuners onto MiniTiouner-Express boards and testing each unit.
73...de Ken W6HHC
73...de Ken W6HHC
Franck,
Try seting Group to 210.0.0.10 and source to 0.0.0.0
- Charles
- Charles
Hi Charles,
yes it's good, I'm too purist
  for me source is source ..and me ffmpeg stream it is my source
Many thank's
73 Franck F1SSF
Many thank's
73 Franck F1SSF
Hi Folks
Finally got an I7 with intel chip set, Limemini/DATV-Express is performing better, manual is a great help too...THANKS!
Firstly: on S2 QPSK as I increase the Msys from 2.5 to 3 the sound on MT express and Divisor is fine
However sound doesn't work on my Strong Sat box @ <2.5Msys but is fine >3Msys
Can anyone suggest if this stems from the Express/Lime or the Sat box
Secondly: when Msym is increased above 3Msys the twiddle factor has been a challenge to get right
Whilst experimenting sometimes different adjustments require major twiddling
Is there any Twiddle on the fly, auto-twiddle or twiddle calibrator on the horizon, is there a way to calculate it?
There lots of variables and the processing of every PC is different (I could be half the trouble, my processing speed is nothing special)
Increased explanation in the manual would be appreciated, maybe a library of config files or a suggested starting point table
Thanks again for all your great work
Cheers Roger VK5YYY
GOOGLE SAYS: Twiddle- "twist, move, or fiddle with (something), typically in a purposeless or nervous way" sounds familiar
Cheers Roger VK5YYY
Just another quick report that Art WA8RMC has shipped a box of 30 MiniTiouner-Express units to England on April 11, for distribution within EU.
It will probably take at least two weeks to clear customs.
73...de Ken W6HHC
73...de Ken W6HHC
Hi Charles and alls,
I am desperate
 ,I use normally my LIME in UDP input mode, I wanted to test my pluto again, I return with my LIME and I still find my problem, DATVExpress is deaf in UDP. I did not change anything, fire all, stream, listening are OK....
What do you think about this? What do you use like IP segment ? Thank you very much
EDIT POST 21/04/19 > I find my problem.
I had meanwhile plugged my pluto that uses the IP address: 210.X.X.X, but this address is outside the standardized IP values. So I handed 230.X.X.X, and it works, sorry for the confusion.
I corrected the screenshots above whith correct IP, because they could be misleading.
73 Franck F1SSF
													I am desperate
73 Franck F1SSF
