Returning from Tx in transverter mode
Roberto48
Post by Roberto48 » Wed Nov 28, 2018 8:27 pm
First: my Portsdown is working great, even on 13cm! Thanks to the designers.
But I have a small problem... When switching back from Tx mode, the transverter LED for that band is burning and DIGITHIN-7 = high. After I select a preset the normal band LED is on again. This behavior is only in MPEG2 mode...
Anyone an Idea?
Thanks!
Rob PA0RWE
Re: Returning from Tx in transverter mode
Post by G8GKQ » Wed Nov 28, 2018 9:22 pm
Hi Rob
I think that what you are seeing is as designed. The band and transverter select LEDs were supposed to stay on in receive mode so that the correct receive down-converter could be selected. It sounds like you are transmitting in a transverter mode (is the frequency button split with F: xxx T: xxx ?) and then when you select a preset it is switching to a non-transverter band. However, the behaviour should be the same in MPEG-2 as H264....
Sorry, it is quite complicated and confusing. I have tried to explain it here: https://wiki.batc.org.uk/Portsdown_2018 ... _and_Bands
Some photos of the touchscreen and the LEDs would help.
Roberto48
Post by Roberto48 » Thu Nov 29, 2018 2:24 pm
Thanks for reply!
As far as I can see I'm not in transverter mode. I'm using the 8-band decoder and RF-switch.
The strange thing is that this problem was introduced after I build the Portsdown in a nice enclosure. I checked all the connections twice...
I have added 3 photo's so you can see what I mean.
1st: Normal situation 2: In TX mode and 3: return from Tx. As you can see the green LED is lighted.
I did a factory restore but the problem stays.
BTW: there is no difference between H264 and MPEG-2 anymore....
(2) In TX mode
(2) In TX mode
case (3).JPG (1.1 MiB) Viewed 5381 times
(1) Normal start situation
case (2).JPG (1.08 MiB) Viewed 5381 times
(3) Return form TX
(3) Return form TX
case (1).JPG (1.07 MiB) Viewed 5381 times
Post by G8GKQ » Thu Nov 29, 2018 5:06 pm
Hi Rob
I now remember that I've seen something similar to this before. It's a short-circuit or open circuit in the wiring between the RPi and the 8-band switch board. Probably an open-circuit on the line from pin 7 on the RPi.
Roberto48
Post by Roberto48 » Thu Nov 29, 2018 8:04 pm
I think I found the problem.. It seems that the T-line not becomes real 0 when in normal mode. When I add a pull-down resistor of 10K between the T-line and ground, the problem is over. Maybe some leakage....
Post by G8GKQ » Thu Nov 29, 2018 9:39 pm
Hi Rob
I have just reproduced your problem! Investigating now....
Roberto48
Post by Roberto48 » Fri Nov 30, 2018 10:41 am
OK Dave,
Maybe you have to add a software pull-down for the T - I/O pin.
Good luck!
Post by G8GKQ » Fri Nov 30, 2018 10:46 am
I had seen this problem as a weak glow on the indicator LED that I have on pin 7 on my test rig, but not really thought about it.
Pin 7 has a 50K pull-up by default, and when rpidatv terminates at the end of a "Portsdown", "UGLY" or "DIGITHIN" transmit session, the GPIO is sometimes released because it is used as a clock in "DIGITHIN" mode. This causes it to be pulled high by the 50K and activate the transverter switch.
The perils of shared GPIOs!
I have added a few lines of code to set Pin 7 as an output again at the end of a transmit session, so there may be a brief pulse of pull-up, but with a 10K pull-down this should not be apparent.
The fix will be in the next release (201811300).
Roberto48
Post by Roberto48 » Fri Nov 30, 2018 11:14 am
I understand what is happening! I leave the 10K in place HI!
Thanks for the fix.
Rob PA0RWE
