Express_DVB_Transmitter software install
DD1US
Re: Express_DVB_Transmitter software install
Post by DD1US » Thu Nov 22, 2018 10:03 pm
my name is Matthias, callsign is DD1US. I am new into DATV TX and would like to use my LimeSDR USB (not mini) to transmit on 23cm and 13cm bands.
I have SDR-Console running fine with the LimeSDR, so the USB3 connection and driver from the Laptop to the LimeSDR seems to be fine.
Presently I am running version 1.25 of "DatvExpressTransmitter" dated from June 20th 2017 on my Windows 7 64bit laptop.
It recognizes the LimeSDR and is indeed transmitting but for instance the "PTT" button and "carrier only" button are both not working / have no effect.
Is there a newer version of DATV Express for the LimeSDR and Windows available ? If so where can I get / download it ?
I would like to make sure I am using the latest version for further tests.
Many thanks in advance for any help / feedback.
Kind regards
Matthias DD1US
www.dd1us.de
DD1US
Post by DD1US » Fri Nov 23, 2018 11:52 pm
Dear all,
I found the problem: I had the wrong software version and now with 1.25lp11 it runs.
On 23cm I get +12dBm output power and a clean spectrum, on 13cm however only -35dBm.
Is that what is to be expected ?
Kind regards
Matthias
www.dd1us.de
DD1US
Post by DD1US » Sat Nov 24, 2018 2:00 am
Hi everybody,
I found my problem on 13cm band: I was still using the TX1L port and should have switched to TX1H. Stupid user error ...
Here is a little summary of my results of the 1st evening trying DATV Express and LimeSDR.
https://www.dd1us.de/Downloads/DATV%20T ... 20rev1.pdf
I am very happy with these first results and recognized how much more I will have to learn and in the next days and weeks.
Any feedback is appreciated.
Kind regards
Matthias DD1US
www.dd1us.de
on7mor
Post by on7mor » Sun Dec 02, 2018 3:14 pm
Had the same problem: MSVCP140.dll and VCRUNTIME140.dll not found.
I've searched for these files on my PC, found them en have and copied them to the same map where the executable is.
(DatvExpressTransmitter.exe)
Works for me.
73's
Corné
ON7MOR
Post by radiogareth » Mon Sep 07, 2020 4:04 pm
I'm just filling my 'new' laptop up with nice software and I've run into this redistribution related error. I've downloaded the 2015 32 bit software but I'm unclear where it actually goes in the Program Files (x86) folder?
Or does it install itself where its supposed to? If the latter, its not working - still getting error messages as above.
Any guidance gratefully recd.....
G3GJA
Post by G3GJA » Mon Sep 07, 2020 8:03 pm
Hi Gareth
You need to run the Visual C++ 2015 Redistributable Runtime package from Microsoft.
Download it from https://www.microsoft.com/en-gb/downloa ... x?id=48145
Just run the 64bit version and it will look at your OS and install it in the correct location.
Clive G3GJA
Post by radiogareth » Mon Sep 07, 2020 8:20 pm
Thanks Clive, I've tried that, several times, including 'repair'. Still not happy. Strange as I have managed to install it on other machines without issues.
None of them WIndows 10Pro though.....
G4GUO
Post by G4GUO » Tue Sep 08, 2020 6:40 am
You need the 32 bit version of the Redistributable even if you are using a 64 bit machine as the Express software is built as a 32 bit application.
- Charles
Post by radiogareth » Tue Sep 08, 2020 6:50 am
Thanks Charles, I have repeatedly tried both versions, both uninstall and repair, in isolation and in combination. Odd, it worked off the bat in my Win10 Atom powered tablet. (Limited to 250kS). Now I could crunch bigger SR's it won't work....
Onward....
Gareth.
G4GUO
Post by G4GUO » Tue Sep 08, 2020 7:03 am
The only other thing I can suggest is that you try the repair option when installing the Redistributable but I think someone else suggested that.
If you are using Express hardware you might need to re-install the drivers as Windows keeps removing them when it updates.
- Charles
