7-band local oscillator Ron Mount – G7DOE
Re: 7-band local oscillator Ron Mount – G7DOE
Post by g8gtz » Fri Feb 16, 2018 8:22 am
I think it would be good if someone else who has mastered this process could update this wiki page https://wiki.batc.org.uk/ADF435x_PIC with step by step instructions and screen grabs on how to program the PIC - then we won't have to rely on the South of England programming service!
We can also put some commonly needed .hex and .asm files for the 4351 and 5535 up there for download.
A secondary question - would the same or similar code work for the 4153? http://www.analog.com/media/en/technica ... DF4153.pdf
M0SKM
Post by M0SKM » Fri Feb 16, 2018 10:59 am
Hi Claudio
Please email me the code too; I maybe able to do it earlier. All the software is still loaded and I have the programmer.
At the moment the only thing missing is my memory; I haven't used the software for 18 months :lol:
I'll let Dave know if I'm able to do it.
73 Steve
email address sent by PM.
M0SKM
Post by M0SKM » Fri Feb 16, 2018 5:22 pm
Claudio,
Emailed the hex code for the first of your two files. I also programmed a PIC if you need it.
Unable to test the code as my ADF4351's are all 10MHz Ref.
Let me know if you want the frequencies changed.
Steve
M0SKM
Post by M0SKM » Fri Feb 23, 2018 11:03 am
Following on from the help sent to Claudio I2NDT I have written a guide in .pdf format and added it to the BATC wiki. It covers installation of software suitable for compiling Ron's C code and writing the generated hex file to a PIC. Screen grabs illustrate each stage of the process through to programming the PIC. Thanks to Claudio for doing a test run through the guide which can be found here. https://wiki.batc.org.uk/ADF435x_PIC
Steve
f6fgd
Post by f6fgd » Wed May 11, 2022 1:24 pm
Hello
I can't find where to tighten the registers for 4 frequencies in the program for a peak 12LF1552
Thank you for your help
Michel
G3GJA
Post by G3GJA » Thu May 12, 2022 9:11 am
Michel
You need to modify the fatcontrol.c variables in the section of code highlighted below:
The output frequencies are multiples of 100kHz, so 502 = 50.2MHz, 1465= 146.5MHz, 4370 = 437MHz etc.
Clive G3GJA
FRANCOIS F1CHF
Post by FRANCOIS F1CHF » Thu May 12, 2022 10:15 am
hello
your item number seems bad
I found item 3665662062741
is the good one ?
thanks
F1CHF near Paris France
f6fgd
Post by f6fgd » Fri May 13, 2022 3:24 pm
Hello Clive
thank you for the answer
I understood for 11030 (for 1103Mhz)
Michel F6FGD
for F1CFH not included......
