Coaxial relays and Mini-kits amplifiers
M0YDH
Post by M0YDH » Wed Sep 13, 2017 11:59 am
Hello all
As noted in an earlier post I'm stuck with what to do to finish my 70cm Mini-kits amplifier at the point where the instructions end. I put the amp module on a wooden base and fascia then wired it up. There's a relay with signal power from a battery for now. I took it to CAT17 but ran out of workshop time and courage to turn it on! The filters that I made did get attention and thank you to Noel and Clive for setting these up.
It's time to choose a relay arrangement. I'd like to switch between coax bypass and amp TX. I didn't know that coax relays are either expensive or treasured heirlooms. Mini-kits sell SPDT relays that handle 20W or more at up to 3GHz. Does one buy a pair of these to switch between coax centres at the input and at the output? They're about 15 Aussie dollars each.
David Holman M0YDH
Re: Coaxial relays and Mini-kits amplifiers
Post by g8gtz » Tue Sep 19, 2017 8:58 am
Ah yes, you'll notice the people in the know dive on equipment at rallys to see what relays are inside :-)
At 70cms you need to be reasonably careful, particularly on the output relay - something like the minikits units or this one http://www.ebay.co.uk/itm/Amphenol-318- ... 2568408287 are OK. (BNC / Ntype / SMA generally indicates an OK relay for 70cms - the golden rule is never use PL259s on any frequency above top band!)
On the input I would tend to use this type of thing - http://www.ebay.co.uk/itm/RS-349-686-SP ... 2048751672 although I would never pay £25 for one and you can pick them up at rallys for a couple of quid!
A good paper to read is Ian White's DG8 pre-amp article - http://www.ifwtech.co.uk/g3sek/vhfdx/dg8-preamp-v7.pdf - it's designed around 145 MHz but cover a lot of good practical engineering practice for pre-amps etc and does talk a little bit about the need for good relays.
The problem only gets worse as you go up in frequency and at 5.6GHz the relay (which will need to be sma or N type) will probably cost more than the FPV kit!
Post by g0mjw » Tue Sep 19, 2017 5:26 pm
I almost agree Noel - excepting the use of PL259s on top band. Unfortunately we are often forced to by the equipment manufacturers but in general I try to avoid them completely.
For 70 cm you can use reasonably cheap BNC relays like those above and the Cx540 which are often available surplus. For microwaves 23cm and down you need microwave relays. These come in many types but the most common are TNC, N or SMA. Good N-type realys (and I don't mean CX520s) tend to be expensive. They do turn up inside equipment, but rarely. SMA relays are much more common for about £10 and up at a rally or microwave round table. It helps to know what you are looking for, RLC, Radiall, Teledyne etc.
Don't be put off if it has a 28V coil or 4 ports (usually a transfer relay). Ratings can be estimated here http://www.rlcelectronics.com/index.php ... id=5&id=61
Post by g8gtz » Tue Sep 19, 2017 6:23 pm
As Mike says 24 / 28v coils are not a problem these days - you can just use a 12>24v buck up converter from that auction (not) website - I've just updated the 5.6GHz wiki page with similar comments: https://wiki.batc.tv/5.6_GHz
One other point is it pays to use sequenced switching on tx / rx changeover as follows:
To go to Tx:
1) Turn off receiver pre-amp
2) Switch ant c/o relay to transmit
3) Apply power to PA
To go to rx
a) Turn off Tx
b) Switch ant c/o relay to recieve
c) Apply power to pre-amp.
This ensures you don't try to switch the expensive relay when the transmit is still on. It also protects your pre-amp by switching it off before you transmit.
A very simple single chip design is shown at the bottom of this page on the wiki : https://wiki.batc.tv/PTT_and_band_switching
EDIT - just realised there is a lot of information here that should be captured on the wiki so we can find it in the future!
I have created a new page at https://wiki.batc.tv/Antennae_changeover_relays
73 Noel
M0YDH
Post by M0YDH » Fri Sep 22, 2017 9:53 am
Many thanks both of you. The wiki is good. My station for 70cm DATV is the first one I've attempted to self build. I ordered the Amphenol relay and if I choose a second one Dave G7MEG offered me second one for input. I may simplify as this is a dedicated DATV amp do just one output relay between rx and tx.
W1GHZ does a sequencer too.
David M0YDH
M0YDH
Post by M0YDH » Sun Oct 01, 2017 2:13 pm
Hello Noel
Further to your advice, I found that Transfer relays with SMA connectors to be better value on Ebay and struck lucky with the pair pictured below which I purchased in person from a trader in Wolverhampton. I went to meet Stew who turns out to be a broadcast radio and communications engineer with a house full of surplus gear that he has to sell. [The 1.5kW dummy load was as big as a labrador dog!]. N.B. he has some super inter-digital filter that he plans to re-align for 437MHz on his VNA
The 5 port 4 way was described thus:-
DC- 12.4GHz 5 Port 4 way 24V SMA Coaxial relay 850W - 85W (@100MHz -12.4GHz)
This is a used but good condition 4 way changeover relay, 24v coils, plus revertive contacts to indicate the made position if switch-over confirmation is needed.
The specs are at http://www.rlcelectronics.com/products/ ... eries.html
with a power graph at http://www.rlcelectronics.com/index.php ... id=5&id=61
Would you be able to add notes on revertive contacts and their application to ensuring safe switching on the Wiki ?
The other relay is a "SR-TC relay, plus an explanation of the numbering system is at;
http://www.rlcelectronics.com/products/ ... eries.html "
I think I'll only need one aerial on 5.6GHz when I build that rig at some point next year!
David M0YDH
Anyone want this circuit?
20170930_Relay Controller in L Band Switcher.jpg (220.87 KiB) Viewed 7455 times
2 RLC coax relays bought from billybob90210
20170930_Coaxial Transfer Relays bought today.jpg (208.18 KiB) Viewed 7455 times
Post by g0mjw » Sun Oct 01, 2017 3:01 pm
Sounds like a successful spree.
The 3, 4 and 6 way relays are relatively common and not too expensive because people don't realise what they are. However, they are not usually transfer relays, they connect the centre port to one of the outer ports. You need to be careful using them for TX/RX switching as there isn't really anything to prevent you from activating more than one port at the same time, which means you could connect the TX to the RS. Some sort of fail safe is advisable but these are best suited to switching between multiple antennas or signal switching.
The transfer relay is ideal for what you are trying to do. It does the job of two SPST relays (take care the isolation is sufficient). Be careful with power ratings, I have seen these melted on 10GHz in key down modes. Stick to less than 10W and it ought to be OK though.
I don't know if your relay is a latching one. If it is W6PQL has a PCB to drive it.
