Can anyone please advise how to get rid of random numbers in..... "edit your streams details"..... page that has suddenly appeared in the ...."stream"..... box, it does not respond to delete keys but stops my computer streaming.
John M1CNJ
Mystery default numbers
Re: Mystery default numbers
Hi John, I think I have an idea what's happening, see picture attached.
The Html is for the bottom blue space below stream and chat, as seen on many repeaters etc.
I'm sure Noel will reset this for you if you get stuck, if he gives you new details then look at his guide, probably Step 3...
http://www.batc.org.uk/Getting_Started/streamguide.pdf
Peter
Peter
- E.G..jpg (85.13 KiB) Viewed 6772 times
Hi John,
Peter is correct and I can help if needed - also take a look at this page on the wiki - it has the instructions you need:
https://wiki.batc.tv/Streaming_to_batc. ... ve_Encoder
And a document here http://www.batc.org.uk/Getting_Started/streamguide.pdf
73 Noel - G8GTZ
73 Noel - G8GTZ
Hi Peter and Noel
With head held low I offer apologies for not obeying the rules as set out on screen.
When I first started streaming many months ago I never added a new stream consequently the stream number never changed and thought that it was a permanent feature even though instructions plainly indicated otherwise.
Many thanks for your patience.
John M1CNJ
John M1CNJ
