Built boards
Once the design is finalised, built and tested Portsdown modulator boards will be available from the BATC shop and will just require the fitting of the supplied 5v regulator - a normal leaded component.
This is the easiest way but there will be a delay whilst they are manufactured and tested - in particular Chinese New Year starts in 2 days time and ends on February 4th which means they will not be available before the middle of February.
Roll your own
For those wanting to construct the board themselves, the blank PCB will also be made available from the BATC shop - there will be a small quantity of blank boards available as soon as the BoM is finalised, which may be this week.
We will publishing a bare bones parts list, or Bill of Materials, as an .xls file which you can upload to Digikey - you then simply checkout and pay Digikey and it will automatically order all the parts you require to construct the board, which will arrive bagged up marked with circuit references. This is the recommended way to order your parts if you decide to build the board yourself.
Or if you prefer to do it the hard way, a full parts list will also be published on the wiki and you can then order the parts from your own supplier.
We will be putting up more information as we finalise the design but to get you started the board layout has just been put on the wiki at https://wiki.batc.tv/Filter_Modulator_build
Enjoy
