RBTVMOD
g6pep
Re: RBTVMOD
Post by g6pep » Thu May 26, 2016 4:23 pm
G4KLB wrote:Silk screen now on the Wiki, more PCBs in the BATC Shop ............ off to work now.
Thanks for that.
I wonder whether, in your haste this morning, you missed my question about artwork. I seem to remember your writing that you didn't design the PCB layout yourself but rather that someone else did it - hence the reason for asking who to contact.
John.
G4KLB
Re: RBTVMOD
Post by G4KLB » Thu May 26, 2016 5:17 pm
Hi John,
The Artwork is on the Wiki now if you would like to make your own PCBs.
Colin
g6pep
Re: RBTVMOD
Post by g6pep » Thu May 26, 2016 10:40 pm
Thanks.
John.
VK5YYY
Re: RBTVMOD
Post by VK5YYY » Wed Jul 13, 2016 1:59 pm
We connected the I/Q output from the GPIO bus of RPi to an old school I/Q modulator from the junk box
2 1K pots were applied from the I and Q outputs to ground and a 1uf capacitor to isolate the wiper from the modulator
Hey presto we got a MER of 15, much simpler than half a digilite, but a bit crude
One of the quadrants has a high level , now to figure out how to bias these things
A bit of filtering wouldn't go astray
Can anybody supply any info on how these older style modulators were biased, an application note or a circuit
It's done with constant current from what I can gather
couldn't be simpler
couldn't be simpler
I/Q modulator circa 2000
F6DZP
Re: RBTVMOD
Post by F6DZP » Fri Aug 12, 2016 7:30 am
With my first prototype using the LTC filters (before the RBTVmod version), I have done some test using a SMIQ-03 IQ modulator. I could get good result and MER, but we are obliged to reduce the value of I and Q to a max of 0.5v if I remember well and take care of the offset.
When all is well set, you get a good result.
Jean-Pierre F6DZP
