Another impossible item ! Insuloid cable cradle loop
Posted: Sun Oct 29, 2023 11:54 am
by G8GQS
These are the correct rubber loops to secure the cables to the guide bars. Our stores did not provide quite enough! so we hope someone is able to help.
They are marked Insuliod size 4 and 5 and we need about 12 size 5 and 5 size 4 or thereabouts.
Photos show:-
The Loops ( size 4)
Close up
The back of the technical tailboard on MCR21 www.mcr21.org.uk
The front of the technical tailboard.
Need to find the right thing for originallity. Hope you can help.
I did try using rubber "o" rings which looked most promising, but after a few weeks all of them had failed at the point were the ends were glued together. Apparently no use under tension!
Best regards
the MCR21 team. G8GQS
