FT290 mod
Posted: Sat Sep 18, 2021 1:09 pm
by G0DQH
Hi Folks
The S meter is full scale & the mod is to fit a i meg resistor across the base & emitter of Q1014.
Can anyone tell me please where Q1014 is on the board please, as there are no markings.
Ta
Re: FT290 mod
Posted: Sat Sep 18, 2021 1:27 pm
Hi James
I have e-mailed you the information that you requested.
Re: FT290 mod
Posted: Sat Sep 18, 2021 7:22 pm
by G4NZV
I resolved the problem with the S meter going full scale in a different way which maybe worth trying before modifying your FT-290R MK1.
My FT-290R MK1 had not been turned ON for a number of years being stored in a warm cupboard. When I turned it on all was fine, however after a couple of days all of a sudden the S meter went full scale or somewhere in between. I was going to try the 1Mohm resistor modification however after leaving the FT290R turned ON powered from 12vDC for about a week and also transmitting and receiving many times, effectively exercising the PTT in both SSB and FM. The S meter slowly started to work correctly returning to the left-hand side. Now it rests where it should on the left-hand side with no input signal and responds correctly giving an indication of the signal strength in all modes, TX power level and battery voltage.
I am not 100% sure why this worked however my guess is the electrolytic capacitors slowly reformed themselves.
Please share your solution to the problem in case my FT290 subsequently fails in the future.
73 Steve
