Comtech 23cm boards chips IC's
keng8vdp
Post by keng8vdp » Mon Sep 18, 2017 6:58 pm
Looking for the standard PIC chips to fit 23cms boards from Comtech. RX and TX
Many thanks .. Ken G8VDP
g7vnpkevin
Re: Comtech 23cm boards chips IC's
Post by g7vnpkevin » Sun Sep 24, 2017 11:06 pm
YOU CAN GET THEM ON EBAY THE NUMBER IS 131260947540 FOR THE NEW UP GRADED CHIP
keng8vdp
Post by keng8vdp » Mon Sep 25, 2017 12:47 pm
Hi Kevin, thanks for the reply.
It isn't the LCD control chip I need ( I believe that is what Mobicomm is selling on eBay )
Its the chips that come with the boards from the supplier.
Many users remove those when using an LCD controller, which is what I did around 12 years ago. I've since misplaced them dispite searching.
I've obtained some other Comtech boards from a silent key and don't wish to use an LCD controller with these hence my request " Wanted Comtech Chips/ICs "
Thanks again.. Ken
i2NDT
Post by i2NDT » Mon Sep 25, 2017 1:03 pm
Ken,
looking deeper in the Mobicomm ebay shop I found this chip:
http://www.ebay.it/itm/DFM-PLL-Control- ... 1e97876e7d
although it is only for the RX board...
maybe you can write to them asking for the TX one!
best 51
de
i2NDT Claudio
i2NDT Claudio
Dalmine, Italia
Post by g8gtz » Mon Sep 25, 2017 5:03 pm
Hi Ken
They are just standard 16F628 PICs - blank ones on ebay for less than £3.
I was given a set of all the hex files by Giles G1MFG for distribution as needed - I'm sure we put them on the BATC website somewhere but if not I have a copy here.
g7jfi
Post by g7jfi » Wed Oct 04, 2017 10:41 am
If you are still stuck I can do you a pre-programmed 16F84A that drops straight in.
I have code for 23cm & 13cm TX & RX. This is not copyright code, I reverse engineered how the module is programmed and wrote my own from scratch.
Let me know if you want one, I guess about £6 posted would cover it.
Terry G7JFI
keng8vdp
Post by keng8vdp » Tue Oct 31, 2017 3:55 pm
g7jfi wrote:If you are still stuck I can do you a pre-programmed 16F84A that drops straight in.
Terry G7JFI
Very Kind Terry, I'll take you up on that. Please pm me.
Ken G8VDP
( I've pm'd you yesterday )
keng8vdp
Post by keng8vdp » Tue Oct 31, 2017 4:02 pm
g8gtz wrote:Hi Ken
Thanks Noel, its been about 20 years since I used my pic programmer. I would need to try and remember how I did it. It's just a distant blurr in the fog of my brain as is the location of said programmer !
I will try and take up Terry's offer but if that fails I'll get back to you.
Much appreciated though, Ken G8VDP
