Amplifier
Posted: Sat Aug 26, 2017 5:22 am
by sean2e0saf
Looking for a driver amp for my dtx1
1 to 2mw drive
The dtx1 is -5dbm around 0.35mw
Cash here or trade a analogue transmitter
Re: Amplifier
Posted: Sat Aug 26, 2017 6:47 am
Any particular frequency?
Re: Amplifier
Posted: Sat Aug 26, 2017 7:32 am
by G4HTZ
I might be selling my Dg0ve 60w 70cms amp .....if it's 70cms your after ..also got the 70cms filter
Re: Amplifier
Posted: Sat Aug 26, 2017 2:11 pm
by sean2e0saf
Yes sorry guys 23cms i need...
But has to be around 1 to 2 mw drive or less
Re: Amplifier
Posted: Sat Aug 26, 2017 3:31 pm
The standard 23cms amplifier from minikits should do what you want. The 18W 23 cms module will give you 3W output for DATV
http://www.minikits.com.au/electronic-k ... -Amplifier
It needs about 40mW for full output so you will need a driver amplifier. Somthing like the Gali 84 or 74.
That's too much gain for one box so keep them separate. Also you probably need some attenuation.
If all of that is too much for you - Bert Modderman does a built version and has options for lower power drive - around 0 dBm.
Re: Amplifier
Posted: Sat Aug 26, 2017 4:53 pm
by sean2e0saf
yes the mini kits driver board is probably all i need as i already have a bert amp..! its around 80mw drive for 18watts out fm so i would probably get around 10watts digital with a clean signal..
does anyone here have a driver amp they like to sell..?????
before i order a mini kits one..
Re: Amplifier
Posted: Sun Aug 27, 2017 12:30 am
by oe7dbh
Re: Amplifier
Posted: Sun Aug 27, 2017 12:38 pm
by sean2e0saf
I dont see anything i can use darko..
I need
0.032 mw -5dbm input and 80mw 29dbm outputs amplifier
Unless the -3db to 210mw maybe ok.. and i use the dtx1 at less rf drive to the amplifier.. i may have to attenuate the output of that
Inc shipping to wn68ns for this amplifier darko
