Wanted 23cms module
lee2e1ljl
Wanted 23cms module
Post by lee2e1ljl » Sun Jun 17, 2012 1:31 pm
wanted, 23cms 1watt pa for use with a commtech 50mw board complete with heatsink if possible
or looking for 500mw or 1 watt transmitter or board, am close to the repeater just not quite fully in with the 50mw
leejlewis@hotmail.co.uk
thanks
G4OHV
Re: Wanted 23cms module
Post by G4OHV » Fri Jun 22, 2012 9:58 am
try Mini-Kits at http://www.minikits.com.au/about.html
regards
Col
g4bbh
Post by g4bbh » Mon Jul 02, 2012 1:32 pm
The MiniKits EME162-1200 1W amplifier will do it (the specs that come with it actually specify 800mW out at 1dB compression) but you may have to select different attenuator resistor values to match the Commtech. They quote 18mW drive for 800mW output with no attenuator. It comes with components for an optional 5dB attenuator (on board). Does what it says it does. Takes 280mA. Needs a small 20mm square heatsink. If you ever go digital don't expect much more than 60mW to 100mW output with good linearity. Digital is very unforgiving.
Dick G4BBH
