Amplifier
sean2e0saf
Amplifier
Post by sean2e0saf » Sat Aug 26, 2017 5:22 am
Looking for a driver amp for my dtx1
1 to 2mw drive
The dtx1 is -5dbm around 0.35mw
Cash here or trade a analogue transmitter
23cms AATV from io83qn ( wn68ns )
23cms DATV from i083qn ( wn68ns )
70cms DATV from io83qn ( wn68ns )
wimo shf-2344
parabeam 70cms/18ele
Re: Amplifier
Post by g0mjw » Sat Aug 26, 2017 6:47 am
Any particular frequency?
G4HTZ
Re: Amplifier
Post by G4HTZ » Sat Aug 26, 2017 7:32 am
I might be selling my Dg0ve 60w 70cms amp .....if it's 70cms your after ..also got the 70cms filter
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
sean2e0saf
Re: Amplifier
Post by sean2e0saf » Sat Aug 26, 2017 2:11 pm
Yes sorry guys 23cms i need...
But has to be around 1 to 2 mw drive or less
wimo shf-2344
Re: Amplifier
Post by g0mjw » Sat Aug 26, 2017 3:31 pm
The standard 23cms amplifier from minikits should do what you want. The 18W 23 cms module will give you 3W output for DATV
http://www.minikits.com.au/electronic-k ... -Amplifier
It needs about 40mW for full output so you will need a driver amplifier. Somthing like the Gali 84 or 74.
That's too much gain for one box so keep them separate. Also you probably need some attenuation.
If all of that is too much for you - Bert Modderman does a built version and has options for lower power drive - around 0 dBm.
sean2e0saf
Re: Amplifier
Post by sean2e0saf » Sat Aug 26, 2017 4:53 pm
yes the mini kits driver board is probably all i need as i already have a bert amp..! its around 80mw drive for 18watts out fm so i would probably get around 10watts digital with a clean signal..
does anyone here have a driver amp they like to sell..?????
before i order a mini kits one..
wimo shf-2344
oe7dbh
Re: Amplifier
Post by oe7dbh » Sun Aug 27, 2017 12:30 am
sean2e0saf
Re: Amplifier
Post by sean2e0saf » Sun Aug 27, 2017 12:38 pm
I dont see anything i can use darko..
I need
0.032 mw -5dbm input and 80mw 29dbm outputs amplifier
Unless the -3db to 210mw maybe ok.. and i use the dtx1 at less rf drive to the amplifier.. i may have to attenuate the output of that
Inc shipping to wn68ns for this amplifier darko
wimo shf-2344
