Shop update - Serit tuners and Portsdown LO filter
The place for announcements on the latest stock items and for your feedback on items that you would like to see in stock
Post by g8gtz » Sat Apr 01, 2017 2:18 pm
We've just ordered 100 more Serit tuners - should be available in 5 weeks (early to Mid May). These are the version with an amplifier in the front end, which we were not made aware of when we made the original order, and will be slightly more expensive but will not require the additional line amplifier.
Mike G0MJW is redesigning the main MiniTiouner PCB so you do not need an adapter PCB to use the Serit - these will hopefully be available at the same time as the tuners.
We still have stock of the Serit adaptor board if you want to use the new tuner with your existing MiniTiouner board.
We have sold all the Portsdown LO filter boards and due to the small IC package, we have just asked for a quote for full assembly of the board - we will either ordering that or if too expensive will be getting some more blank boards from China.
Whilst there are still some in the shop, we have just asked for a quote to assemble a batch of V2 Filter modulator boards - these will be on a 4 week lead time, so if you want one, buy it now!
Return to “BATC Shop”
