Serif Tuner FTS 4334 LV
Help and support for the BATC DTX1 ATV digital encoder and modulator system
Paul B
Post by Paul B » Sun Aug 20, 2017 8:20 pm
Hi all regarding the Minitiouner V2
The parts list refers to Serif Tuner FTS 4225 But the tuner I have is a FTS 4334 LV
The other thing is the only dater I can find says it tunes from 250 to 2150
But the article tells me it tunes from 143.75 to 2450
Can someone please clarify the above and explained the difference
Regards Paul B
Re: Serif Tuner FTS 4334 LV
Post by g8gtz » Sun Aug 20, 2017 9:27 pm
Hi paul,
This page on the wiki explains the difference between the 2 Serit tuners https://wiki.batc.tv/Serit_tuner - they are pin compatible and are totally interchangeable.
Not sure about the 2nd point but presume the manufacturer only guarantees operation above 250 MHz but F6DZP found it works down to 143 MHz - and it does!
Paul B
Post by Paul B » Sun Aug 20, 2017 10:03 pm
Hi Noel
thank you for the reply to my question about Sarif 4334 LV and pointing me to the wiki
I did not notice the part number change in the information on my earlier visit to the wiki
regards Paul B
Return to “BATC DTX1”
