BPF 2m
Re: BPF 2m
Check out these videos
https://youtu.be/iLZUKnzKSlg?si=KSeJAZY5amkm6UZC
https://youtu.be/AwU2jcANmls?si=bAgDcPO6k2e7VhzL
both a good watch
73 John G7JTT
both a good watch
73 John G7JTT
Re: BPF 2m
Thanks John
I met the "Vic" in the bar at GQRP Convention.
I had also seen these videos prior to my question.
I guess I will have to order one and give it a go.
73 Nigel M0NDE
73 Nigel M0NDE
Re: BPF 2m
I'd just include one after the PA, there are some nice cheap amps that re-use MRF186 ('Linear PA' on Ali Express) devices and the PCB includes a filter and VSWR sensing, they go very well on 2m. There area also 70cms versions too and other amps that use a small brick PA and predriver that do 5W DATV on 70. Perfect for local use.
If you fancy a DIY then W6PQL has excellent filter designs for QRO on his website. https://www.w6pql.com/filter_+_coupler_+_detectors.htm
If you used 500V silver Mica caps (or better ATC ones) you would be fine on 2m power levels.
Re: BPF 2m
Thank you Gareth for the link. On my next pension day I will order one of these kits for 2m.
73 Nigel M0NDE
73 Nigel M0NDE
