Pluto problems
G8DGN
Pluto problems
Post by G8DGN » Fri Aug 09, 2024 1:45 pm
Hi, I just bought a Pluto (from an official source) and am having trouble communicating with it.
When plugged in as a USB storage device, I can set its IP and ping it. However it times out on ssh root@IP_address, and no http server is running.
The same result occurs with a USB to ethernet adapter.
Should its ssh client and http server be running - out of the box?
Thanks,
John
g8lce
Re: Pluto problems
Post by g8lce » Sun Aug 11, 2024 7:49 am
Hi John,
When you set the IP, are you setting it in the right place? For an example I have copied part of my Pluto config below. See the [USB_ETHERNET] part where the IP address information is added to fit in my network and used with the USB to ethernet adapter . The [NETWORK] part you leave as that is what address the Pluto has when connected via USB.
# Analog Devices PlutoSDR Rev.B (Z7010-AD9363)
# Device Configuration File
# 1. Open with an Editor
# 2. Edit this file
# 3. Save this file on the device USB drive
# 4. Eject the device USB Drive
# Doc: https://wiki.analog.com/university/tool ... ustomizing
[NETWORK]
hostname = pluto
ipaddr = 192.168.2.1
ipaddr_host = 192.168.2.10
netmask = 255.255.255.0
[WLAN]
ssid_wlan =
pwd_wlan =
ipaddr_wlan =
[USB_ETHERNET]
ipaddr_eth = 192.168.123.105
netmask_eth = 255.255.255.0
gateway_eth = 192.168.123.254
[SYSTEM]
xo_correction =
udc_handle_suspend = 0
[ACTIONS]
diagnostic_report = 0
dfu = 0
reset = 0
calibrate = 0
Martin G8LCE
Re: Pluto problems
Post by g0mjw » Sun Aug 11, 2024 8:34 am
Have you installed the windows drivers?
G8DGN
Re: Pluto problems
Post by G8DGN » Wed Aug 14, 2024 6:29 pm
Thank you very much for the suggestions. Yes I had misunderstood the various IP addresses, and adding to the confusion was an intermittent USB adapter. All seems to be working fine now.
Return to “Getting Started?”
