problems problems with the mini tiouner
thedvbdreamer1
Post by thedvbdreamer1 » Mon Sep 25, 2023 6:20 pm
Hello members,
I do not get it anymore.
The manual of the mini tiouner states that before you want to use the mini tiouner, you must first check the programs to ensure they are functioning properly and the green lights must be on. Until last Saturday they were on green, and I had programs from a few `s 90% in the green display.
Since last night I can't get it to work anymore, and no matter what I try the lights stay red and the program stops.
I have already tried the USB ports several times, but nothing
Help
Basil
Re: problems problems with the mini tiouner
Post by Basil » Mon Sep 25, 2023 6:52 pm
Do you have access to another PC that you can load the Minitioune software on and it on try that computer? If not I'd try another USB cable after removing and reinstalling the Minitioune software on your current PC. I am assuming all power supplies on the Minitiouner board are present and correct? Good luck!
Best regards,
thedvbdreamer1
Post by thedvbdreamer1 » Mon Sep 25, 2023 7:42 pm
it works again, another USB cable.
cause ; unknown.
a question; how should I program it; Use Tioune Data Reader V0.2b.
And a few parts of ; USB master (lnb / 22Khz Ts1 and Ts2) buttons do not work and USB aux does not work.
Why is that? Use the Mini-Tiouner Express.
thedvbdreamer1
Post by thedvbdreamer1 » Tue Sep 26, 2023 7:00 pm
And, can someone tell me what to do to get that working.
Best regards
Post by g0mjw » Tue Sep 26, 2023 7:32 pm
They don't work because they are not implemented in that model.
thedvbdreamer1
Post by thedvbdreamer1 » Tue Sep 26, 2023 8:07 pm
Oke ,thank you Mike
Mvg
Return to “Getting Started?”
