1st-Timer listening for a Repeater... Idents? Test Cards?
Ingenuator
Post by Ingenuator » Tue Jan 26, 2021 6:54 pm
Hi All,
I'm listening out for my first repeater, GB3ET on 23cms (nearby I *think* as it says it's about 7 miles away)
A dumb question from a novice:-
Do ATV repeaters broadcast an 'ident', like voice repeaters?
I also heard some repeaters revert to beacon when not in use? (send a test card?)
Is there something common to all ATV repeaters you can listen for - if you don't have any way of keying them up, that is!
Best 73s!
Re: 1st-Timer listening for a Repeater... Idents? Test Cards?
Post by M0DTS » Tue Jan 26, 2021 8:41 pm
According to this post on the forum the repeater is Transmitting 24/7 but hopefully someone nearby will confirm.
viewtopic.php?f=100&t=6347
The signal maybe a single testcard, slideshow or even videos.
Some repeaters Transmit 24/7 and others similar to voice repeaters, but they often have a longer hang time when the activation signal disappears.
Try monitoring/calling on 144.750, there maybe someone nearby who can help.
M0SKM
Post by M0SKM » Tue Jan 26, 2021 9:34 pm
You can see what ET is transmitting by checking the stream.
https://batc.org.uk/live/gb3et?forcehtml5=true
73 Steve
Ingenuator
Post by Ingenuator » Wed Jan 27, 2021 12:11 pm
Really helpful :P - I'll have a listen this weekend hopefully..
Coverage map is hopeful but If anyone knows whether it's getting into Banbury town areas, please do let me know.
Dave.
Return to “Getting Started?”
