RSGB Monday @8 - ATV presentation
Discussion and Planning for Events and Streaming Activity
Post by g8gtz » Fri Dec 03, 2021 1:54 pm
Following on from his “Advances in Amateur Television” talk at the 2017 RSGB convention, Noel Matthews, G8GTZ will be presenting on the latest developments in the ever-evolving world of Amateur TV.
Noel will give an overview of ATV activity in the UK and in particular how the use of Reduced bandwidth (RBTV) signals has enabled ATV QSOs on the lower VHF bands. He will give an introduction to the QO100 geostationary satellite which has enabled QSOs with fellow DATV operators as far away as Brazil, India and South Africa.
Noel will also be describing how the development of Software Defined Radio (SDR) based hardware and powerful single board computers such as the Raspberry Pi has revolutionised the development and capabilities of amateur radio dedicated products.
He will describe how it is possible for radio amateurs to build an advanced touch screen multimode narrowband and Digital ATV transceiver covering 50 MHz to 10GHz for under £350.
https://batc.org.uk/live/rsgb
https://rsgb.org/main/blog/tonight-at-e ... ews-g8gtz/
Return to “Events”
