Please email me at secretary@BATC.TV and I''ll forward the message to Kevin.Many years ago I worked in the cable TV industry and acquired a lot of equipment when the company closed down. (It had a bit of a history Rediffusion, Maxwell Cable TV, Metro Cable TV and then CableTel/NTL before closing)
I have some items to dispose of, I would rather someone make use of them than giving them to the scrapman. They are free, I need to drag them all out of storage and they would have to be collected.
List that I have found so far:
Phillips PM5535 pattern generator
Phillips PM5544 pattern generator
Phillips PM5582 IF-UHF up-converter
Phillips PM5581 IF-VHF up-converter
Tektronix PAL waveform monitor
2 off Jeffold/GI 50-450MHz PAL modulators
2 off HP141T Spectrum analyzers, 110MHz plug-in and 18GHz plug-in. (Maybe a thrd 1.5Ghz)
3 off Tracking generators (I think the multi cable was missing when I got them)
Wiltron 640? Scaler Network Analyzer
Approx 6-8 Dynamco 7100 oscillscopes some with TV trigger plug-in
Unaohm pattern generator
This pile is a mixture of working and not, I may have more. I know there are certainly some Katrein amplifiers and maybe some other 75 ohm test equipment, attenuators and cables etc.
I'm located in Pontypool South Wales.
Junk for disposal
Junk for disposal
I received this email from Kevin GW0PUH:
Re: Junk for disposal
Does the 18 GHz 141T plug-in work, usually have duff first mixer and these are not amateur repairable being wirebonded hybrids. If it does the I am interested.
David G8FNR
Davezawadi@yahoo.co.uk
David G8FNR
