Prme Focus 1.8m Dish, not motorised
G0LJF
Post by G0LJF » Thu Aug 25, 2022 10:39 am
New - unused. Unable to use at this location.
Buyer collects from North Stockport, please.
I suggest lying it flat, face down, on a truck bed or large enough van floor. To keep it straight.
I don't have the original packing crate.
https://primesat.eu/satellite_dishes_pr ... 1800cm.php
I have made a home brew POTY mount for it but I have not tested that - it is all unused.
Comes with C120 LNB and Chaparral ring 'horn' (as supplied).
£200, it was over £800.
PM me, or my email is on QRZ.
73, Mike
G0LJF
Re: Prme Focus 1.8m Dish, not motorised
Post by G4EWJ » Thu Aug 25, 2022 12:52 pm
Hi Mike,
'Not motorised' as in fixed mount rather than polar?
G0LJF
Post by G0LJF » Thu Aug 25, 2022 2:20 pm
Hi Brian,
Yes, its fixed. It has an elevation fine control on a long Brass screwed rod.
Please see the manufacturer's link I included. Many photos there.
As for Azimuth, that would be according to the clamp alignment on the pole. As it usual.
73, Mike
Post by G4EWJ » Thu Aug 25, 2022 5:16 pm
Thanks.
m0lcr
Post by m0lcr » Thu Aug 25, 2022 10:45 pm
Hi, I’m not far from Stockport so could I come over to have a look at the dish system please.
73 Vincent M0LCR
G0LJF
Post by G0LJF » Fri Aug 26, 2022 10:23 am
Hi Vincent,
Please note this is not a "system" as you put it. Its a brand new dish, unused, unmoved. It was delivered and stored.
Nothing else. I don't want to mislead you.
With all the fittings etc... and supplied LNB.. home brew POTY adaptor. All brand new. All unused. Not tried out. Everything is new / as supplied.
The POTY adaptor was tested for focus/distance using the dish feed arms arranged as per dish fitment. This is adjustable.
The original LNB clamp IS supplied. Its just the LNB clamp that I have made a replacement part for. You will see. You do not have to use it.
I hope I described it accurately. If not please say. Please check the manufacturers link I posted.
You have a PM with my contact details. Will be pleased to see you of course.
One last point the dish WAS supplied in the vertical alignment, in a crate. In a cardboard box. It MAY be possible to move it vertically. Up to you.
73,
G0LJF
