Winterhill Receiver
G1LWX
Winterhill Receiver
Post by G1LWX » Fri May 21, 2021 10:41 am
Spare Winterhill receiver for sale.
Pm for details
PA3CX
Re: Winterhill Receiver
Post by PA3CX » Tue Jun 22, 2021 7:01 am
Hello G1LWX,
I'm interessed in the winterhill because i can not finnish mine, no stock of some parts.
It's not possible to pm you yett so i'm trying this way.
Best regards
ramon
G1LWX
Post by G1LWX » Tue Jun 22, 2021 8:23 pm
Hi Ramon
You can contact me on mike.berry40@gmail.com
73s Mike
Post by g0mjw » Tue Jun 22, 2021 8:38 pm
What parts are not stocked? You can almost always make substitutions.
PA3CX
Post by PA3CX » Wed Jun 23, 2021 5:44 am
viewtopic.php?f=14&t=7459&sid=b44a88368 ... 7a2bc585e7
Hello Forum members,
Still looking for some parts for my Winterhill.
Found stock on Farnell but i'm not able to order.
28C0236-0JW-10 - Ferrite Bead, Axial Leaded, 998 ohm, 5 A, 0.01 ohm Fabrikant: LAIRD
240-2493-ND
i need 4 of these.
None stock on digikey and farnell,
MIC29300-12WT - LDO Voltage Regulator - Fixed, 26V input, 12Vnom/3 A out, TO-220-3
576-1118-ND
i need 1
Any members have these spare in the shack and willing to sell them ?
Best regards
ramon
Post by g0mjw » Wed Jun 23, 2021 7:34 am
The ferrite beads are not a critical component. They are there to clean up the switching supply noise. You can replace them with a small 6x10mm ferrite bead with a few turns of thin enamelled copper wire suitable for a couple of amps. Alternatively you could use one of the wire ended ones like this adapted to fit.
https://uk.rs-online.com/web/p/ferrite-beads/6835247/
This raises a general point. You can substitute alternate compatible parts. Take a look at the schematic. If in doubt, ask.
The 12V linear regulator is there for protection. It allows for people putting in more than the 14V upper limit of the switching regulators by accident. If you are very careful, and you can guarantee not to put in more than 12V, and I mean 12V, really 12V, not 13.8V you can bypass it for testing while waiting for the part to come back in stock. That should get you up and running.
G1LWX
Post by G1LWX » Wed Jun 23, 2021 7:38 am
Hi Ramon
For the Laird ferrite bead you can use Digikey part no 240-2491-nd
it uses the same bead so just push one of the wires through the spare hole
For the regulator I used a sm one Digikey part no 576-2222-nd
I straightened the legs and used a small clamp arrangment to fasten both devices
to the case instead of using two bolts.
I may have some spares
Mike G1LWX
PA3CX
Post by PA3CX » Thu Jun 24, 2021 5:17 am
Thanks for useful info, tips and tricks !
73' ramon
Jabi
Post by Jabi » Wed Jul 21, 2021 5:40 pm
Hola:
Estoy interesado en el Winterhill.
Por favor me puede enviar fotos y precio?
73,s de Jabi, ea2aru.
G1LWX
Post by G1LWX » Wed Jul 21, 2021 6:28 pm
Hola jabi
Por favor contácteme al
