Unused Titanium Satellite C1W-PLL C band LNBF
Posted: Sun Nov 15, 2020 2:38 pm
Titanium Satellite C1W-PLL C band LNBF,bought for DATV but never used it as went another route. Still in original packaging
£30 shipped UK mainland. PM me if interested
G4FRE
C1W-PLL Wideband LNBF Specifications
Input Frequency Range 3.40 ~ 4.20GHz
Output Frequency Range 950 ~ 1750MHz
L.O. Frequency 5150MHz
Noise Temperature 15K typical
LO Stability (over temp ex offset) ± 50Khz / ± 10Khz at operational temperature
LO Phase Noise @ 1Khz -72dBc
LO Phase Noise @ 10Khz -81dBc
LO Phase Noise @ 100Khz -90dBc
Conversion Gain 65dB typical
Gain Flatness ±4dB
Gain Variation ±1dB / 27 MHz
Image Rejection -45dB
Crosstalk Isolation 20dB typical
Control Signals Ca [V/CR] 11.5 ~ 14.0V
Control Signals Cb [ H/CL] 16.0 ~ 20.0V
DC Voltage 11 ~ 20Vdc
Current 145mA [max]
Output VSWR 2.0 : 1
Temperature Range -22 ~ +140°F / -40 ~ +60°C
Relative Humidity 0 ~100% condensing
Polarization Type (cast ±45° scale) Linear (w/dielectric for circular)
Output Impedance 75Ω
Connection F-Type / 3GHz / Female
Weight 10.1oz / 286g
Construction Precision Cast Aluminum
Hardware Silver Zinc Coated Steel Allen Head (w/tool)
Housing / Scalar Finish Polyurethane Powder (chip resistant)
Color Snow White / Natural Cooling Fin
Feedhorn Cover RF Low-loss (blue color)
Dimensions (w/o scalar) 7⅝ (l) x 4⅜ (h) x 2¾ (w) in 185 (l) x 87 (h) x 68 (w) mm
Scalar Type * Flat - Prime Focus, 3 Ring
F/D with included Flat Scalar 0.32 ~ .44+ (cast scale)
Mount Type with Flat Scalar Single pole, Tripod or Quad legs
* Optional Conical Scalar Kit – SC1 Offset Type Dish with F/D .5 ~ .8
G4FRE
Gain Flatness ±4dB
Current 145mA [max]
Output VSWR 2.0 : 1
