*** Lots of kit. Make an offer ***
M0SAT
Post by M0SAT » Wed Apr 26, 2017 10:29 pm
Our contest group "the Drowned Rats" has managed to acquire a lot of broadcast kit and we are going to be raising funds for our group by selling it at Kempton Park rally on Sunday 30th April. So if you'd like to help fellow amateurs and add to your shack (I'm fairly sure there is kit in here that will be of interest to some of you in ATV land) please make an offer and if we can agree a price you can collect at Kempton, if you're visiting or we can arrange collection/delivery separately.
Please email interest to m0sat@drownedrats.uk
Thurlby Electronics Ltd Digital Bench Multimeter 1503
Iwastu SS-5711C Oscilloscope 100mhz w/Universal Counter
Sony PVM-6041QM 6inch Colour monitor
Metrix OX 530 Analog Scope
Metrix OX863 Analog Scope 100MHz
JVC TM-10E - K Monitor
JVC TM-600PN Monitor
Marconi Instruments 80Khz-1040Mhz Signal Generator. model 2019.
HP 3780A PATTERN GENERATOR ERROR DETECTOR F637
Tektronix TAS 465 100MHz 2 Channel Oscilloscope Analog Scope
HP spectrum analyser down converter 3730B + 3736B 1.7 to 4.2 Ghz plug in RF MOD
HP/Agilent 1673G Standalone Logic Analyzer
TTC FIREBERD 6000A COMMUNICATIONS ANALYZER
rohde&schwarz video analyzer uaf
thurlby 30v-2a pl320
Farnell LT30-2 Stabilised Power Supply, 2 x 0 - 30Vdc, 2 Amp
Black Star Jupiter 2000 0.2Hz - 2MHz function generator
RACAL DANA 9919 UHF FREQUENCY COUNTER
Clare V242 Check calibration unit
HP 8558b Spectrum Analyzer 0.1- 1500MHz
Delta Electronika PSU SM6020 (60v@ 10a, 30v @20A)
Panasonic WV-CM 1020 (monitor)
Marconi Instruments 80Khz-520Mhz Signal Generator. model 2018.
HP/Agilent 1663G Standalone Logic Analyzer
Tekronic 1485R Waveform Monitor
AGS2100 Advanced Studio gateway
Altei Sat Rx
Tanberg TT1282 IP RX
Tanberg TT1262 RX
Tekronic TSG271 Pal TV generator
Farnell Triple O/p PSU( Tops 3D) 17v @1a, 6v @4a
Antritsu Spectrum Analyzer MS610B 10khs to 2Ghz
VideoTek TVM-730 Viedo analyzer
VideoSkp III Swof BN424104
Sound Technology 1710A Distortion Measurement System
Racal Instruments 9480 Time & frequency Mainframe
Antritsu System Analyzer ME453M RX and ME453M TX
We also have the following components:
MSA-0685 Cascadable Silicon Bipolar MMIC Amplifier Agilent 85-SMD
Magnatec L78Sxx L78S24CV, Single Linear Voltage Regulator, 2A 24 V, 3-Pin TO-220
BFQ68 Transistor Silicon NPN Case SOT122 Make NXP Semiconductors
BLV33F LINEAR VHF RF POWER TRANSISTOR
BLV33 VHF BAND, Si, NPN, RF POWER TRANSISTOR PHILIPS
SD1489 NPN SILICON RF POWER TRANSISTOR
TPV597 1.0 W, 470–860 MHz UHF LINEAR POWER TRANSISTOR
XILINX XC3142A
(1-14) pF LOT OF 2 VARIABLE PISTON PRECISION TRIMMER CAPACITORS
TCC593 (TCC 593) - TRANSISTOR ST
XCF5206EFT40 32-BIT, 40MHz, RISC PROCESSOR, PQFP160
RF Termination Microwave Resistor Dummy Load RFP 150W 50ohm 150watt 150HN50
TPV5055b UHF Linear power Transistor
sean2e0saf
Re: *** Lots of kit. Make an offer ***
Post by sean2e0saf » Sat Apr 29, 2017 6:25 pm
how much are we looking for
23cms AATV from io83qn ( wn68ns )
23cms DATV from i083qn ( wn68ns )
70cms DATV from io83qn ( wn68ns )
wimo shf-2344
parabeam 70cms/18ele
G4ZCN
Post by G4ZCN » Fri Jul 21, 2017 8:48 am
Can you confirm which model the Altei Sat Rx is?
best regards,
Barry
G4ZCN
Barry
G4ZCN
E: b.grylls@ntlworld.com
