up for sale is a scientific atlanta d9850 IRD
looking for £40+ £20 shipping its in a big box..!
collection is ok as is a meet up..!!
this receiver is ideal for 23cms repeater site or just shack use however it is 19" rack mount
it is not your average digital satellite receiver in any way
4 rf inputs you can have any combination of antenna feed's
i.e. on antenna one
23cms 1249 rx
23cms other freq rx
23cms repeater rx
antenna 2
uhf datv rx via upconverter
antenna 3
a better rx antenna same as antenna one
antenna 4 a dish input for maybe 10ghz digital (( it will come ))
many other configurations possible
you are better reading up about the ird than me explain all..!
but here are the specs
4 RF Inputs
· 2 Audio Inputs
· SDI
· ASI in
· ASI out
· Ethernet, Ethernet Enhanced
Analog Cable Program Distribution
Composite video and balanced audio outputs can be connected to analog modulators for analog cable distribution. Four mono audio channels or two stereo pairs are available for primary audio programs, as well as secondary audio programs (SAP). For example, primary program audio could be carried on one of the stereo pairs, while SAP audio is carried on the other stereo pair.
Digital Cable Program Distribution
Uplink-addressable transport output provides MPEG program streams for digital tier program delivery, so quality video programs can be distributed efficiently to households equipped with digital set-top boxes.
Digital Program Replacement
Digital program replacement (DPR) allows programmers to transparently switch their primary service to an alternative service in the digital domain in blackout applications for cable digital tier distribution. This feature remaps the packet identifier (PID) information from the primary service to an alternate service, allowing downstream devices to continue to operate seamlessly. This helps make alternative programming available in the digital tier without operator intervention.
Cable Headend Advertisement Insertion
For flexible advertisement insertion configurations, this receiver provides four types of outputs:
· Dual-tone multi frequency (DTMF) cue tone
· Cue trigger support, with eight open collector outputs
· One programmable contact closure
· Digital program insertion (DPI) messaging using Asynchronous Serial Interface (ASI) output
Low-Speed Data Output
Asynchronous utility data (up to 38.4 kbps) is available through an RS-232 interface.
IP Data Output
IP data can be received and output at rates up to 50 Mbps.
Main Features
• Four L-band inputs
• PowerVu conditional access with Data Encryptions Standard (DES) or Digital Video Broadcasting (DVB) descrambling
• Support for Basic Interoperable Scrambling System (BISS) conditional access
• 4:2:0 NTSC and PAL (B, G, I, D, M, and N) video decoding
• Aspect ratio conversion (4:3, 16:9 and 14:9) with Active Format Descriptor (AFD) control
• MPEG and Dolby Digital (AC-3) audio decoding
• Four audio outputs providing either two stereo pairs (four mono channels) of balanced audio each with the ability to use part of their output for applications such as SAP, DTMF, etc.
• Line 21 closed caption and V-chip support
• Utility data via RS-232
• IP data output up to 50 Mbps over Ethernet
• DVB VBI (WST, WSS, and VPS)
• PowerVu VBI, including North American Broadcast Teletext Standard (NABTS) and World System Teletext (WST)
• DVB or Imitext subtitling
• DTMF cue tone and cue trigger outputs for advertisement insertion
• Fingerprint trigger
• Field upgradeable software and security
• Front panel liquid crystal display (LCD) for control and monitoring
• 64 user-editable preset configurations
• Uplink addressable decoder output control (VBI, audio routing, DPI, and ASI output)
• Simple Network Management Protocol (SNMP) for setup, control, and monitoring
• Web browser interface for easy setup, control, and monitoring
• Digital program replacement providing uplink control of program replacement in blackout areas
Optional Features installed
• ASI input (up to 68.5 Mbps)
• SDI video output with embedded audio
• AES-3id digital audio output
SCIENTIFIC ATLANTA D9850 POWERVU PROFESSIONAL PROGRA
sean2e0saf
Post by sean2e0saf » Fri Jun 13, 2014 5:56 pm
23cms AATV from io83qn ( wn68ns )
23cms DATV from i083qn ( wn68ns )
70cms DATV from io83qn ( wn68ns )
wimo shf-2344
parabeam 70cms/18ele
wimo shf-2344
Jump to
- Forum Admin
- ↳ Announcements
- ↳ Feedback
- ATV General Discussion
- ↳ Getting Started?
- ↳ General ATV Discussion
- ↳ DATV - Digital ATV
- ↳ ARISS HamTV
- ↳ LimeSDR Mini
- ↳ CQ-TV, The BATC Magazine
- ↳ BATC Bursary Grants
- ↳ Spectrum matters
- ↳ Streaming
- ↳ EMF Compliance
- ↳ Narrow Band DATV (RB-TV)
- ↳ DXSpot.TV
- ↳ Deutschsprachiges Forum
- ↳ Events
- ↳ DigiThin
- ↳ DigiLite
- ↳ BATC DTX1
- ↳ CaribouLite RPi Hat
- Adverts
- ↳ For Sale
- ↳ Wanted
- ↳ BATC Shop
- ATV Repeaters
- ↳ UK ATV Repeaters
- ↳ GB3BH
- ↳ GB3CZ
- ↳ GB3DK
- ↳ GB3EN
- ↳ GB3ET
- ↳ GB3EY
- ↳ GB3FB
- ↳ GB3FT
- ↳ GB3FW
- ↳ GB3FY
- ↳ GB3GG
- ↳ GB3GV
- ↳ GB3GW
- ↳ GB3HV
- ↳ GB3IF
- ↳ GB3IT
- ↳ GB3IV
- ↳ GB3JT
- ↳ GB3KM
- ↳ GB3LO
- ↳ GB3LX
- ↳ GB3MV
- ↳ GB3NQ
- ↳ GB3NV
- ↳ GB3PV
- ↳ GB3RT
- ↳ GB3RV
- ↳ GB3SQ
- ↳ GB3TG
- ↳ GB3TM
- ↳ GB3TN
- ↳ GB3TT
- ↳ GB3TV
- ↳ GB3TZ
- ↳ GB3UD
- ↳ GB3VR
- ↳ GB3UT
- ↳ GB3VL
- ↳ GB3VV
- ↳ GB3VX
- ↳ GB3WV
- ↳ GB3YT
- ↳ GB3ZZ
- ↳ Internet-only Repeaters
- ↳ IO91LC
- ↳ IO91WN
- ↳ IO92GQ
- ↳ Overseas ATV Repeaters
- Archive
- ↳ GB3AT
- ↳ GB3FT
- ↳ GB3FV
- ↳ GB3CT
- ↳ GB3AD
- ↳ GB3BG
- ↳ GB3DH
- ↳ GB3DJ
- ↳ GB3KT
- ↳ GB3NV
- ↳ GB3OT
- ↳ GB3PT
- ↳ GB3TB
- ↳ GB3TX
- ↳ GB3VW
- ↳ GB3XG
- ↳ GB3XT
- ↳ GB3XV
- ↳ GB3XY
- ↳ GB3YT
- ↳ GB3YX
- ↳ For Sale Ads Archive
- ↳ Wanted Ads Archive
- ↳ CAT 16 and BGM 2016
- ↳ CAT 17
- ↳ CAT18
- ↳ Mini-Conventions in 2019
