wimo shf 2328
Posted: Sun Feb 23, 2014 6:02 pm
by sean2e0saf
WIMO SHF 2328 23cm-Yagi 28 Element 15,4 dBD
this antenna is in near immaculate un bent condition
it is also a original wimo NOT a copy
less than half price £70 ovvno
prefer collection but may be able to post it will be expensive tho
i can meet up for fuel cost's i will travel up to 80miles for £15 which will be cheaper than post
the antenna is only being sold as i have just bought a shf-2344
Multiple-optimized design according to DL6WU
All holes of the boom drilled automatically by robot - extreme small tolerances
Elements automatically cut, length tolerance less than max. 0.1 mm
Elements are exactly centered and automatically mounted by robot
Non-compromise dipole: N-connector, balun made of semi-rigid cable, all connectors sealed, connection box additionally filled.
The "SHF 2328" model is the ideal start-up model for 1.3 GHz; the antenna is a mere 1.5 m long and has 16 dBD gain. The mechanical data is almost identical to the other SHF-antennas. The electrical characteristics are absolutely identical with the SHF long yagis except for the 3-dB beamwidth and the gain.
The antennas have an very high f/b ratio because of the use of 8 reflectors. This is in particular important for high-gain yagis: even the highest gain gets useless if unwanted signals or interferences are being received from the back side of the antenna. EME or SAT freaks enjoy our antennas due to the low backward noise scatter (from the surface of the earth). All nuts, bolts and washers are manufactured of stainless steel. For those antennas with support strut also the mast clamp itself is made of stainless steel (where else do you find this?).
The antennas are delivered pre-mounted with all elements already in place. They can be assembled in about 10 minutes;
and it does not take an engineering approach to install the antenna and get into the air...
