My friend Harold has asked me to place the following list on the forum. If there is anything you are interesed in please contact him directly or me in extremis. Brian G8GQS
This is an up date list of some of the stuff I wish to sell on. Harold G8BPU.
Sony camera DXC- M3 with a Canon zoom 9.5 -143 mm, and a G1MFG TX to give total mobility.
Frequency can be set at any part of the 23/ 24 cm band, see CQTV 204 for my update mod's and CQTV 159 for the walk about aerial, All mounted on the camera. The camera has only 20 on it' hour meter!
Eight NPA-1 Battery’s, two battery chargers BC-1WA, one battery box adapter DC8
One quick release tripod plate.
One 23cm TV receiver.Srx100 with mods to bring it up to a high spec. built in deviation calibrator to measure both out going, and received video and audio. Nearly all the mods have been published in CQTV. one 23 cm TV transmitter using a Mini-circuits CO phase locked loop, O/p frequency displayed on a micro wave modules frequency counter some of the design ideas came from Allan Bennett in CQTV between 2000 and 2004, 6 MHz sound carrier is phase locked as CQTV 173 deigned by Bob Platts. Mic and line I/p under AGC control. PA is a 2watt M67715. Built in delayed RX TX timer to switch the mast head pre amp off in the panel aerial before TX, change over rely is the Amphenol 316-10082-3 CQTV 125/199. Both TX and RX powered from 240v rack mounted or can go portable from 12v.
Sennhieiser mike comprising:-
Me66 mike and k6 power unit, one outer cover and pistol grip MZW426
One MZS 16 (don’t have the fur wind muff cover (Doogal).
Red Head Lamp with day light filter, stand and 6 spare 800w lamps
Radio mike made by audio, comprising tie clip mike, TX on 174.1 MHZ, RX and aerial
Panasonic 8 inch colour monitor TC- 800 12 volt power only.
Panasonic 9 inch monochrome monitor WV5340 240v
One Panasonic U-Matic recorder player NV 9210. Not been used for more than 10 or15 hours, i.e. for demonstration only. With service manual.
Four KSP-20 U-Matic new tapes
Panasonic VHS portable system Nv-M7B in its case with mains unit/ charger
Decca 19 inch rack mount TV tuner R4011. It has a 6 output VDA, and one 600Ω balanced audio output. 240v with service manual.
Four top 70cm AM TX requires attention.
Shibaden 625 SPG. SG104 240v with service manual.
J Beam 70 cm Hi gain aerial MBM48 15.7dBd gain.
Panel aerial for 23 cm as CQ TV 182 with a pre amp fitted see CQTV 169 by G4LXC.
24 cm collinear aerial as CQ TV 127 two stacked
Tektronix vectorscope PAL 1421 + a matching waveform monitor, both in V. good working order.240v.
Levell AC Micro voltmeter Type TM3B 1Hz – 3Mhz (V and mV ) large five inch meter calibrated in mV, µV, and a scale in dB -20 to+6dB.center zero.
American AMF video distribution amp five 5 O/p, 240v.
12 way VDA see CQTV 198 240v
10 way ADA see CQTV 142 240v
10 way video and audio switcher CQTV 150 240v rack mounted.
Colour test card generator CQ TV blue book 240v rack mounted.
Electrocraft PAL encoder PE-84 with built in gen lock SPG.240v rack mounted
Time lapse VHS recorder.240v
Datavideo 4:2:2 frame synchronizer TBC type TBC-1000.12v. Using the TBC to gen lock the SPG to the VHS or 23cm RX TV.
Two Sony HVC-3000p cameras 12v
There is a long list of valves to go as well.
Please contact Harold Skelhorn on skel7(at)btinternet.com or 01625 573242 (Macclesfield) remove (at) and replace @
I will not be monitoring this thread. regards Brian S
ATV shack clearance
Jump to
- Forum Admin
- ↳ Announcements
- ↳ Feedback
- ATV General Discussion
- ↳ Getting Started?
- ↳ General ATV Discussion
- ↳ DATV - Digital ATV
- ↳ ARISS HamTV
- ↳ LimeSDR Mini
- ↳ CQ-TV, The BATC Magazine
- ↳ BATC Bursary Grants
- ↳ Spectrum matters
- ↳ Streaming
- ↳ EMF Compliance
- ↳ Narrow Band DATV (RB-TV)
- ↳ DXSpot.TV
- ↳ Deutschsprachiges Forum
- ↳ Events
- ↳ DigiThin
- ↳ DigiLite
- ↳ BATC DTX1
- ↳ CaribouLite RPi Hat
- Adverts
- ↳ For Sale
- ↳ Wanted
- ↳ BATC Shop
- ATV Repeaters
- ↳ UK ATV Repeaters
- ↳ GB3BH
- ↳ GB3CZ
- ↳ GB3DK
- ↳ GB3EN
- ↳ GB3ET
- ↳ GB3EY
- ↳ GB3FB
- ↳ GB3FT
- ↳ GB3FW
- ↳ GB3FY
- ↳ GB3GG
- ↳ GB3GV
- ↳ GB3GW
- ↳ GB3HV
- ↳ GB3IF
- ↳ GB3IT
- ↳ GB3IV
- ↳ GB3JT
- ↳ GB3KM
- ↳ GB3LO
- ↳ GB3LX
- ↳ GB3MV
- ↳ GB3NQ
- ↳ GB3NV
- ↳ GB3PV
- ↳ GB3RT
- ↳ GB3RV
- ↳ GB3SQ
- ↳ GB3TG
- ↳ GB3TM
- ↳ GB3TN
- ↳ GB3TT
- ↳ GB3TV
- ↳ GB3TZ
- ↳ GB3UD
- ↳ GB3VR
- ↳ GB3UT
- ↳ GB3VL
- ↳ GB3VV
- ↳ GB3VX
- ↳ GB3WV
- ↳ GB3YT
- ↳ GB3ZZ
- ↳ Internet-only Repeaters
- ↳ IO91LC
- ↳ IO91WN
- ↳ IO92GQ
- ↳ Overseas ATV Repeaters
- Archive
- ↳ GB3AT
- ↳ GB3FT
- ↳ GB3FV
- ↳ GB3CT
- ↳ GB3AD
- ↳ GB3BG
- ↳ GB3DH
- ↳ GB3DJ
- ↳ GB3KT
- ↳ GB3NV
- ↳ GB3OT
- ↳ GB3PT
- ↳ GB3TB
- ↳ GB3TX
- ↳ GB3VW
- ↳ GB3XG
- ↳ GB3XT
- ↳ GB3XV
- ↳ GB3XY
- ↳ GB3YT
- ↳ GB3YX
- ↳ For Sale Ads Archive
- ↳ Wanted Ads Archive
- ↳ CAT 16 and BGM 2016
- ↳ CAT 17
- ↳ CAT18
- ↳ Mini-Conventions in 2019
