For sale, my spare 24cm DIGILITE board, BUILT & TESTED & Boxed , ( Latest Ver 5.70 board ) inc FT2232 USB programmed module ( does not inc 1249 mhz LO )
Also included built & tested 20mw-30mw + seperate booster amplifier, when run into standard M68719 brick amp will produce 10-15w.
Digilite board & amplifier have 4x SMA sockets & final output Chasis/Bulkhead SMA fitted for quick & easy connectibility
£200 ppg posted or collected from Stockport.
Also fitted & heatsinked to back of unit is two seperate voltage regulators to provide 8v DC & 5v DC to power amplifier board & local osc board
front of unit is switched for power on/off with seperate USB status & power status LED's
Just connect to 12 or 13.8v DC & plug & play DATV
